Setting up a 2700 for ADSL2+
Started by Jup, Nov 04, 2010, 11:55:33
The profile will take time to rise, you should get a 1.25mb profile in a few days, as long as the error count is low. See http://www.idnetters.co.uk/forums/index.php/topic,1904.msg31527.html#msg31527
If you could manage a BT speedtest it would helpful to see the current IP Profile.
MisterW
QuoteRate:    1152 kbs    288 kbs
Something not quite right there, why is the upstream only 288? , should be 448 even on ADSL1.
That looks like a fixed rate 1Mb connection to me...
Jup
Thanks for the quick replies guys,
Here is the speed test result..
Download speedachieved during the test was - 649 Kbps
For your connection, the acceptable range of speedsis 400-1000 Kbps.
IP Profile for your line is - 750 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.36:20.94:65.7 (SBE:NBE:PBE)
Can i get off the fixed rate if the line is indeed fixed?
Probably profile, Jup, since your speed increase is not huge. Can you manage a BT speed test.
Jup
Hi Rik,
Is the speed test I posted 1 post up the test you need to see? I did the test from here http://speedtester.bt.com/
Cheers
Sorry, came in on the previous page and was preoccupied. :blush:
Your profile should rise to 1M, but it looks to me like you've been put on a fixed rate 1M service, not Max.
Jup
Can i get that changed or should i just wait a few days and see what happens?
Cheers
Jup
Hehe sorry Rik, take your time mate :thumb:
OK, you've been remodulated to ADSL Max, but then capped at 1M in order to stabilise your line. Give it a week and see if things remain stable. If they do, call support and they'll lift the cap and see if you can retain stability.
Jup
Ah ok, I'll keep an eye on things over the next week. Thanks again for the help guys :)
Cheers
Jup
This mornings stats
Modem Type:    Built in modem - ADSL
DSL Line (Wire Pair):    Line 1 (inner pair)
Current DSL Connection:
   Down    Up
Rate:    768 kbs    448 kbs
Max Rate:    768 kbs    892 kbs
Noise Margin:    16.0 dB    20.0 dB
Attenuation:    56.0 dB    31.5 dB
Output Power:    16.2 dBm    12.4 dBm
Protocol:    G.DMT Annex A
Channel:    Interleaved
DSLAM Vendor Information    Country: {46336} Vendor: {IFTN} Specific: {47473 }
ATM PVC:    0/38
Rate Cap:    768 kbs
Attenuation @ 300kHz:    56.0 dB
Uncanceled Echo:    -15.7 dB    Ok
VCXO Frequency Offset:    -14.9 ppm    Ok
Final Receive Gain:    34.5 dB    Ok
Impulse Noise Comp. Tones:    0    Ok
Excessive Impulse Noise:    0    Ok
BT speedtest...
Download speedachieved during the test was - 497 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.23:22.11:67.66 (SBE:NBE:PBE)
Is this normal as it seems to be going the wrong way, max rate down was 1500 all last night:(
MisterW
QuoteRate:    768 kbs    448 kbs
Looks like its been moved from a fixed 1Mb to a normal ADSL1 connection since the upstream's now back at 448.
The target noise margin has gone up though, which would tend to indicate a 'banded profile'. Only problem is I didn't think they were used on ADSL1 and also there isn't a profile with a maximum synch of 768k, very odd...
Jup
Cheers for the quick reply MisterW,
I'll keep watching it today and see what it does.
Cheers
Jup
Hi all,
Stats for today..
Rate:    960 kbs    448 kbs
Max Rate:    960 kbs    912 kbs
Noise Margin:    15.0 dB    20.0 dB
Attenuation:    56.1 dB    31.5 dB
ATM PVC:    0/38
Rate Cap:    960 kbs
Attenuation @ 300kHz:    56.1 dB
Uncanceled Echo:    -12.1 dB    Ok
VCXO Frequency Offset:    -17.7 ppm    Ok
BT Speedtest..
Download speedachieved during the test was - 367 Kbps
For your connection, the acceptable range of speedsis 100-500 Kbps.
IP Profile for your line is - 500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.76:17.88:70.37 (SBE:NBE:PBE)
Seems my profile is getting lower than ever :( Take it my best course of action is to sit tight for a few more days?
Yes, be patient and resist the temptation to reboot the router.
Jup
Jup
Hi again,
This is my stats after a week..
   Down    Up
Rate:    832 kbs    448 kbs
Max Rate:    832 kbs    892 kbs
Output Power:    16.1 dBm    12.4 dBm
ATM PVC:    0/38
Rate Cap:    832 kbs
Uncanceled Echo:    -12.8 dB    Ok
VCXO Frequency Offset:    -14.2 ppm    Ok
I seem to be a little worse off than when I started. Any advice on where to go from here?
Cheers
Have a word with support, see if they can reset the target noise margin for you.
Jup
Hi Rik,
I called support and they reset the target noise margin for me no problem. I'll post back once I start seeing some changes. Thanks again for the help, much appreciated :)
Cheers
NP. Good luck with the change. Did they tell you when (if) you need to reboot the router?
Jup
Hi Rik,
No they never mentioned rebooting the router, just said that i'd see some change in about 4 hours. Should I reboot do you think?
Cheers
