BT2700HGV ISP unlock
Started by Bazru, Nov 18, 2010, 15:34:12
Bazru
Hi to all!
At last I have adjusted VoIP. I was connected to VoIP provider Rynga.com Perfectly works.
Now at me 3 more questions:
1. What for the button on a forward part with drawing Wireless?
2. How it is possible to make backup my settings of  router?
3 .Sometimes happen disconnect from ISP. I do not understand for what reason.
Thanks!
1) It's to allow you to give people access to your network without having to enter a password. I don't think any of us have got it to work.
2) Afaik you can't with a 2700.
3) I don't know the telecomms companies in your countries, but here a loss of synchronisation, the top of the bottom pair of green/red LEDs would indicate noise on the line causing the router to disconnect and connect afresh (resync as we generally refer to it). If the bottom of the two lights goes out or turns red, the authentication between you and your ISP has failed, or your router is unable to establish a PPP session, usually due to a fault in the telecomms company's network.
Bazru
Rik, thanks for reply!
Here mine Detailed Log:
INF 2010-11-26T21:55:11+04:00 lmd: dsl0: down (signal lost)
WRN 2010-11-26T21:55:11+04:00 vrsip: Broadband connection lost
INF 2010-11-26T21:55:13+04:00 lmd: device0: dsl0 has no current version set
INF 2010-11-26T21:55:15+04:00 lmd: rnat0: Deleted pinhole[17]: nat_addr=91.191.203.xxx, dest_addr=192.168.1.65, proto=6, alg=0, port=51832
INF 2010-11-26T21:55:15+04:00 lmd: device0: dsl0 has no current version set
INF 2010-11-26T21:55:16+04:00 lmd: rnat0: Deleted pinhole[18]: nat_addr=91.191.203.xxx, dest_addr=192.168.1.65, proto=17, alg=0, port=51832
INF 2010-11-26T21:55:16+04:00 lmd: device0: dsl0 has no current version set
INF 2010-11-26T21:55:16+04:00 lmd: Previous log entry repeated 3 times
INF 2010-11-26T21:55:37+04:00 lmd: dsl0: up G.DMT2+ Annex A interleaved Rate:3374/875 Max:8333/875
INF 2010-11-26T21:55:37+04:00 lmd: dsl0: Margin:13.4/6.3 Atten:18.6/6.9 Power:18.9/12.0
Why this problem? From the provider? From modem options? From my telephone line?
In the UK, I would say it's your phone line - unfortunately, I can't be more precise because I don't know your local telecoms environment. Check that you have no unfiltered devices connected to the line, eg phones.
MisterW
As Rik says we really don't know about your local telecoms systems.
QuoteINF 2010-11-26T21:55:37+04:00 lmd: dsl0: up G.DMT2+ Annex A interleaved Rate:3374/875 Max:8333/875
All I can say is that with those attenuation figures in the UK you would expect a much faster and stable connection.
Check your phone connections as advised by Rik.
Bazru
I have checked up telephone line. My phone is connected through DSL filter, I even have changed the filter (just in case)
Sometimes long works without disconnects, and sometimes disconnects happen often.
Sounds like a bad line then. If you're running Windows, get hold of a copy of Routerstats and run that, the graphs will give us a better idea of what's going on:
http://www.vwlowen.co.uk/internet/files.htm
http://www.vwlowen.co.uk/moreinternet/files.htm
MisterW
Can you post the results from this page on the 2700 http://home/xslt?PAGE=J42&THISPAGE=A02_POST&NEXTPAGE=J42
Bazru
Troubleshooting – DSL Diagnostics
General Information
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 3376 kbps
Downstream Atten. at 300kHz: 11.7 dB
Uncancelled Echo: -21.2 dB Ok
VCXO Frequency Offset: 18.5 ppm Ok
Final Rx Gain: -0.4 dB Ok
Impulse Noise Comp. Tones: 89 Suspicious - impulse noise detected
Excessive Impulse Noise: 0 Ok
Impulse noise protection:  4.53
Delay of latency path:  6.09 ms
Training History
Downstream  Upstream
Time Line  Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY  Rate Max Mgn Attn Pwr CRCs FECs  Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2010/11/27 09:05:48 AMT 1  3374 9077 9069 9069 14.7 14.6 18.5 18.8 0 9 4.53 6.09  722 722 6.3 6.9 12.1 0 2402  G.DMT2+ Annex A Broadcom 229/103 N/A -21.2 18.5 -0.4 89
Bazru
Today since the morning I had a new problem:
My router reboots in itself - since the morning it has rebooted 6 times. And yesterday all the day long worked normally.
Bazru
What is this error?
ERR  2010-11-27T10:26:04+04:00  sip:  _SipFreePkt(): Unknown SIP header type (43)
INF  2010-11-27T10:29:30+04:00  cwmd:  retried session started, server: 'https://pbthdm2.bt.motive.com/cwmpWeb/CPEMgt';, event code(s): '1 BOOT'
WRN  2010-11-27T10:29:36+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T10:29:36+04:00  cwmd:  session failed...
INF  2010-11-27T10:29:36+04:00  cwmd:  session will be retried in 1263098(ms)
INF  2010-11-27T10:51:01+04:00  cwmd:  retried session started, server: 'https://pbthdm2.bt.motive.com/cwmpWeb/CPEMgt';, event code(s): '1 BOOT'
WRN  2010-11-27T10:51:10+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T10:51:10+04:00  cwmd:  session failed...
INF  2010-11-27T10:51:10+04:00  cwmd:  session will be retried in 1408158(ms)
WRN  2010-11-27T11:07:43+04:00  sip:  !!!!! SipEvent1xx() wrong call state
INF  2010-11-27T11:15:00+04:00  cwmd:  retried session started, server: 'https://pbthdm2.bt.motive.com/cwmpWeb/CPEMgt';, event code(s): '1 BOOT'
WRN  2010-11-27T11:15:09+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T11:15:09+04:00  cwmd:  session failed...
INF  2010-11-27T11:15:09+04:00  cwmd:  session will be retried in 1909332(ms)
ERR  2010-11-27T11:16:05+04:00  sip:  _SipFreePkt(): Unknown SIP header type (43)
INF  2010-11-27T11:47:01+04:00  cwmd:  retried session started, server: 'https://pbthdm2.bt.motive.com/cwmpWeb/CPEMgt';, event code(s): '1 BOOT'
WRN  2010-11-27T11:47:09+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T11:47:09+04:00  cwmd:  session failed...
INF  2010-11-27T11:47:09+04:00  cwmd:  session will be retried in 2905977(ms)
It looks like the firmware trying to update itself, I get logs full of that stuff.
Quote from: Bazru on Nov 27, 2010, 05:46:44
Re-booted as if you had killed the power? If that's the case, you probably have a dying power supply, they're a weak point with the 2700.
Bazru
How completely kill program updating?
Means  me it is necessary to buy the new power unit.... Ohhhh.....
You cant stop it trying to update itself. you can only set the address to a non existent one
What firmware are you on? The Tripod site will tell you how to do it for your version, though it looks to me as if it's already safely blocked.
If you see the router shut down completely, ie the power light goes off and then comes back on, check that the power lead is fully inserted, but if it is, chances are it's failing and you will need to get your hands on a new one. I've had a couple fail so far.
MisterW
QuoteImpulse Noise Comp. Tones: 89 Suspicious - impulse noise detected
That's bad news! it's usually caused by external electrical/radio interference being present on the ADSL line.
Bazru
I have such router:
Model: BT2700HGV
Serial Number: 520611xxxxxx
Hardware Version: 2701-100588-005
Software Version: 5.29.107.19
Key Code: 528Y-27G4-A222-22BJ-B22V
Enhanced Services: Internet Access Control
Content Screening
Firewall Monitor
On one method I have made so:
In section:    Advanced – DNS Name table
I have filled:
DNS name                                        IP Address            Entry Type
cwmp.cms.smehomehubrms.bt.com        10.0.0.0            User added
I think it enough for blocking of updating of firmware?
Dear Rik! Tell where it is possible to order the power unit for this router?
Thanks to All!
Are you using a UK PSU at the moment? If so then you be able to get one here http://www.digidave.co.uk/jshop/product.php?xProd=357 I don't know if they ship overseas though.
What Glenn said, Bazru. I'm also wondering whether a UK spec 2700 is suitable for your country?
MisterW
QuoteI think it enough for blocking of updating of firmware?
No , changing the DNS lookup table will not block firmware upgrades.
You need to change the ACS URL as described here http://bt2700hgv.tripod.com/032.htm
Bazru
I chanced it to:
acs_url   https://gw-5-29-117.cwmp.cms.2wire.com
That will do?
Now look on my Detailed Log:
INF  2010-11-27T17:11:33+04:00  cwmd:  retried session started, server: 'https://gw-5-29-117.cwmp.cms.2wire.com', event code(s): '1 BOOT'
WRN  2010-11-27T17:11:42+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T17:11:42+04:00  cwmd:  session failed...
INF  2010-11-27T17:11:42+04:00  cwmd:  session will be retried in 1013869(ms)
ERR  2010-11-27T17:28:08+04:00  sip:  _SipFreePkt(): Unknown SIP header type (43)
WRN  2010-11-27T17:28:09+04:00  sip:  !!!!! SipEvent1xx() wrong call state
INF  2010-11-27T17:28:45+04:00  cwmd:  retried session started, server: 'https://gw-5-29-117.cwmp.cms.2wire.com', event code(s): '1 BOOT'
WRN  2010-11-27T17:29:02+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T17:29:02+04:00  cwmd:  session failed...
INF  2010-11-27T17:29:02+04:00  cwmd:  session will be retried in 643361(ms)
INF  2010-11-27T17:40:02+04:00  cwmd:  retried session started, server: 'https://gw-5-29-117.cwmp.cms.2wire.com', event code(s): '1 BOOT'
WRN  2010-11-27T17:40:15+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T17:40:15+04:00  cwmd:  session failed...
INF  2010-11-27T17:40:15+04:00  cwmd:  session will be retried in 771114(ms)
INF  2010-11-27T17:53:15+04:00  cwmd:  retried session started, server: 'https://gw-5-29-117.cwmp.cms.2wire.com', event code(s): '1 BOOT'
WRN  2010-11-27T17:53:30+04:00  cwmd:  authentication has already been tried once and we still don't get in
WRN  2010-11-27T17:53:30+04:00  cwmd:  session failed...
INF  2010-11-27T17:53:30+04:00  cwmd:  session will be retried in 1898009(ms)
Its OK?
MisterW
Bazru
And still it seemed to me after I have put wireless = mode B only
Were gone disconnects
It can is temporary?
If the disconnections have stopped, your phone company may have been working on the line and have now completed the work.
