BT2700HGV ISP unlock
Started by Bazru, Nov 18, 2010, 15:34:12
Bazru
I think disconnects have stopped because of change wireless mode - "B"
It advise here: http://bt2700hgv.tripod.com/043.htm
But because of it my  wireless network became slow. This not so good solution.
MisterW
TBH I hadn't seen that latest tripod post. My 2700 doesn't seem to have a problem with wireless-G , although I don't use it a lot.
The office one gets used quite heavily from time to time ( I downloaded 300MB at 2.0MB/sec the other day! ) and that doesn't have a problem either.
Bazru
I have the big exchange traffic
Every day:
download - 3-7GB
upload 1-3GB
I use µTorrent 2.0.2 (22150)
You'd benefit from a cable, rather than wireless, connection, then.
Bazru
The router is far from the laptop, there is no possibility  connect a cable
A cable can be up to 100 metres in length.
Bazru
I can not stretch a cable through a wall :)
You could try mains networking, homeplugs as they are usually called. What kind of mains sockets do you have, eg in the UK we use 'square' pinned, 13A fused plugs. That's critical because the plus have to fit your sockets, so we may not be able to make recommendations except in terms of good and bad makes.
Bazru
Thanks, Rik!
But at my home is not present socket for LAN. It is necessary to use WIFI. Let's look as the router will work today.
Please look at the underlined text. What does it mean?
Troubleshooting – Upgrade History
Current Version
Model Number: BT2700HGV
Hardware Version: 2701-100588-005
Software Version: 5.29.107.19
Upgrade Log
Initial Software Version:
upgrade_voice_adsl:  5.29.107
upgraderecovery_adsl:  5.29.107
pre-upgrade:  102280
To be honest, I have no idea, sorry. :(
Bazru
I want to flash  router 6 version of firmware. You advise or not?
Quote from: Bazru on Nov 29, 2010, 18:38:46
There are some problems with V6, especially regarding items missing from the devices list and you cannot go back to V5 after flashing to V6.
I believe so if its an upgrade from v5 and is already working, but not if you are setting it up from scratch.
MisterW
I didn't believe there was a manual way of upgrading to v6. AFAIK the only way is via an 'automatic' upgrade from 5.29.117.6.
Bazru
Quote from: MisterW on Nov 30, 2010, 07:49:09
Here the description as it to make:
_http://bt2700hgv.tripod.com/063.htm
MisterW
Yes, that explains how to configure v6 f/w but it is not available to download from anywhere.
Bazru
Precisely, I have inattentively looked. Sorry :)
And how then I can update to version 6?
MisterW
It is not possible to update to v6.
Bazru
Quote from: MisterW on Nov 30, 2010, 13:19:00
No? without variants?
Gnix62
I have upgraded 2700HGV from V5 to V6, detailed post can be find in this "2-wire 2700 router issue" topic, voip can be set from scratch but troublesome, only benefit is you can set 2 wireless SSID.
MisterW
I can't see any download link on tripod for v6.
Quoteonly benefit is you can set 2 wireless SSID.
You can do that with v5, Fusion and Normal SSID's.
Gnix62
Quote from: MisterW on Nov 30, 2010, 14:59:31
I can't see any download link on tripod for v6. You can do that with v5, Fusion and Normal SSID's.
You can find the Firmware at the section:
http://bt2700hgv.tripod.com/071.htm
I am not using BT V5 so not aware V5 also can set 2 SSID.
MisterW
Gnix2, Thanks for that, I missed that somehow.
Bazru
Gnix2, You tried this firmware?
