No dial tone but still have internet
Started by juiceuk, Dec 07, 2010, 18:40:13
juiceuk
I have no dial tone and cannot make or receive calls but I still have the internet ??? Its syncing lower than normal and disconnecting a fair bit. I've reported it to talk talk and have an engineer coming some time tomorrow pm which I thought was pretty good if they turn up. I've unplugged everything, tried different phones and tried the test socket.
Upstream Speed:   448 kbps
Downstream Speed: 3296 kbps
noise margin upstream: 18 db
output power downstream: 19 db
attenuation upstream: 31 db
noise margin downstream: 11 db
output power upstream: 12 db
attenuation downstream: 50 db
Pings seem all right
C:\Windows\system32>ping -t www.idnet.net
Reply from 212.69.36.10: bytes=32 time=26ms TTL=59
Reply from 212.69.36.10: bytes=32 time=24ms TTL=59
Reply from 212.69.36.10: bytes=32 time=23ms TTL=59
Reply from 212.69.36.10: bytes=32 time=25ms TTL=59
Reply from 212.69.36.10: bytes=32 time=28ms TTL=59
    Packets: Sent = 43, Received = 43, Lost = 0 (0% loss),
    Minimum = 23ms, Maximum = 28ms, Average = 24ms
Control-C
Find it quite funny I still have a pretty decent internet connection with the voice line not working.
The voice line is DC and requires a continuous circuit, ADSL is RF and doesn't - though it's obviously less efficient without.
Call your voice provide and report the fault. Don't mention ADSL (unless your VP is IDNet.)
juiceuk
I've got an engineer booked for sometime tomorrow pm. The hard-line phone seems to have no power so no current makes sense, interested to know what would be the cause of this type of fault?
A line break, either a cable has snapped or a joint has.
juiceuk
juiceuk
All Sorted, knew the engineer well so had a good chat too :)
Downstream Speed: 6240 kbps
noise margin upstream: 27 db
attenuation upstream: 18 db
noise margin downstream: 12 db
attenuation downstream: 35 db
He should have the target noise margin reset as part of the fault clearance, but as he would have been a voice engineer,  I'd suggest calling support and getting them to reset it. Potentially, then, you will be well into the 7M connection range.
