Playstation 3 question
Started by vitriol, Dec 09, 2010, 21:45:19
vitriol
Hello can anyone advise me if the ps3 can output 720p over a component connection.  might be getting one and my tv gas no hdmi and the only connection I've got spare is component.
would like a new tv but not an option at the moment.
any help much appreciated
thanks
vit
If the TV will accept 720p via component you should be fine, the max component out for the PS3 is 1080p for games and 1080i for video according to google.
vitriol
my tv did 720p on the Xbox with no problems.
I take it then that 1080p for movies is only hdmi then?
Something to do with AACS only allowing full resolution (1080p) for video on HDMI/DVI
http://en.wikipedia.org/wiki/Advanced_Access_Content_System#Analog_Outputs
Games should be ok up to 1080p in theory.
vitriol
Thanks Steve you've been a great help.  one more question if I may.  Will it do Bluray movies in 720p via component?  Sorry for being a pain, I just gave to be sure about this specific issue.
Thanks again
See post #2 it gives the list of max resolutions for DVD upscaled and BD movies i.e BD 1080i max for component
http://www.avsforum.com/avs-vb/showthread.php?t=974202
vitriol
