MASSIVE pings
Started by wrtpeeps, May 03, 2007, 13:56:27
alan
Ely, Cambridgeshire
Pinging www.jolt.co.uk [82.133.85.65] with 32 bytes of data:
Reply from 82.133.85.65: bytes=32 time=129ms TTL=58
Reply from 82.133.85.65: bytes=32 time=144ms TTL=58
Reply from 82.133.85.65: bytes=32 time=130ms TTL=58
Reply from 82.133.85.65: bytes=32 time=133ms TTL=58
Ping statistics for 82.133.85.65:
    Minimum = 129ms, Maximum = 144ms, Average = 134ms
Reply from 212.69.36.10: bytes=32 time=152ms TTL=61
Reply from 212.69.36.10: bytes=32 time=142ms TTL=61
Reply from 212.69.36.10: bytes=32 time=166ms TTL=61
Reply from 212.69.36.10: bytes=32 time=140ms TTL=61
    Minimum = 140ms, Maximum = 166ms, Average = 150ms
Alan
RobMc
Hmmm this is quite interesting....
Using my idnet connection...
C:\Documents and Settings\rjm>tracert www.idnet.net
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2   144 ms   142 ms   130 ms  telehouse-gw3.idnet.net [212.69.63.55]
  3   152 ms   135 ms   129 ms  redbus-gw.idnet.net [212.69.63.1]
  4    49 ms    53 ms    52 ms  www.idnet.net [212.69.36.10]
Trace complete.
Using my colleagues idnet connection...
  1     2 ms    <1 ms    <1 ms  10.0.0.2
  2    23 ms    25 ms    27 ms  telehouse-gw3-msdp.idnet.net [212.69.63.51]
  3    18 ms    20 ms    18 ms  redbus-gw.idnet.net [212.69.63.1]
  4    18 ms    18 ms    18 ms  www.idnet.net [212.69.36.10]
Trace complete.
We are both on the same exchange. Tests were done within a couple of minutes of each other. Note different gateway in hop 2.
Rob.
Interesting indeed, Rob - you let him have the fast connection! :)
At 15:42
ping www.bbc.co.uk -n 20
Pinging www.bbc.net.uk [212.58.224.86] with 32 bytes of data:
Reply from 212.58.224.86: bytes=32 time=138ms TTL=250
Reply from 212.58.224.86: bytes=32 time=145ms TTL=250
Reply from 212.58.224.86: bytes=32 time=152ms TTL=250
Reply from 212.58.224.86: bytes=32 time=171ms TTL=250
Reply from 212.58.224.86: bytes=32 time=147ms TTL=250
Reply from 212.58.224.86: bytes=32 time=142ms TTL=250
Reply from 212.58.224.86: bytes=32 time=74ms TTL=250
Reply from 212.58.224.86: bytes=32 time=149ms TTL=250
Reply from 212.58.224.86: bytes=32 time=51ms TTL=250
Reply from 212.58.224.86: bytes=32 time=85ms TTL=250
Reply from 212.58.224.86: bytes=32 time=97ms TTL=250
Reply from 212.58.224.86: bytes=32 time=155ms TTL=250
Reply from 212.58.224.86: bytes=32 time=173ms TTL=250
Reply from 212.58.224.86: bytes=32 time=118ms TTL=250
Reply from 212.58.224.86: bytes=32 time=170ms TTL=250
Reply from 212.58.224.86: bytes=32 time=129ms TTL=250
Reply from 212.58.224.86: bytes=32 time=164ms TTL=250
Reply from 212.58.224.86: bytes=32 time=158ms TTL=250
Ping statistics for 212.58.224.86:
    Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
    Minimum = 51ms, Maximum = 173ms, Average = 135ms
ping www.idnet.net -n 20
Reply from 212.69.36.10: bytes=32 time=150ms TTL=61
Reply from 212.69.36.10: bytes=32 time=61ms TTL=61
Reply from 212.69.36.10: bytes=32 time=118ms TTL=61
Reply from 212.69.36.10: bytes=32 time=141ms TTL=61
Reply from 212.69.36.10: bytes=32 time=161ms TTL=61
Reply from 212.69.36.10: bytes=32 time=167ms TTL=61
Reply from 212.69.36.10: bytes=32 time=117ms TTL=61
Reply from 212.69.36.10: bytes=32 time=143ms TTL=61
Reply from 212.69.36.10: bytes=32 time=116ms TTL=61
Reply from 212.69.36.10: bytes=32 time=137ms TTL=61
Reply from 212.69.36.10: bytes=32 time=148ms TTL=61
Reply from 212.69.36.10: bytes=32 time=145ms TTL=61
Reply from 212.69.36.10: bytes=32 time=136ms TTL=61
Reply from 212.69.36.10: bytes=32 time=129ms TTL=61
Reply from 212.69.36.10: bytes=32 time=169ms TTL=61
Reply from 212.69.36.10: bytes=32 time=125ms TTL=61
Reply from 212.69.36.10: bytes=32 time=144ms TTL=61
Reply from 212.69.36.10: bytes=32 time=135ms TTL=61
    Minimum = 61ms, Maximum = 169ms, Average = 136ms
Namesco:
1172 d/s 275 u/s
Current profile is 2500.
Tracert at 15:48:
  1     5 ms    <1 ms    <1 ms  www.routerlogin.com [192.168.0.1]
  2   175 ms   170 ms   171 ms  telehouse-gw3.idnet.net [212.69.63.55]
  3   131 ms   142 ms   143 ms  redbus-gw.idnet.net [212.69.63.1]
  4   155 ms   153 ms   155 ms  www.idnet.net [212.69.36.10]
Trace complete.
We are on the same second hop, I see.
RobMc
Quote from: rikbean on May 03, 2007, 15:49:57
Her actually  :laugh:
Yes, but she only syncs at 5760 (day one of Max) and I sync at 8128. I prefer the higher max speed with greater latency over slower max speed and lower latency.
Rob.
Quote from: rikbean on May 03, 2007, 15:19:39
Have you run any pings or speed tests? If you have, could you post results please? Thanks. :)
I'm back at work now so can post exact results later. But from memory my sync was about 5100 and the speed test was 500kbps.
wrtpeeps
Date     03/05/07 16:16:28
Speed Down    458.92 Kbps ( 0.4 Mbps )
Speed Up    344.88 Kbps ( 0.3 Mbps )
problem still there.
Don't eat yellow snow.
BT's terminology is Planned Engineering Works but seeing as they omitted (and have admitted) to not informing us of the works then we dispute the "planned" bit. The 'failsafe' systems in place to recover from these works have failed. As such it is now up to us to manually rebalance our pipes. Therefore, some customers may see their connections drop momentarily. We apologise for any inconvenience caused.
Regards
Thanks for the update, Simon.
BT strike again!
Thanks, Simon. Wouldn't life be easier if BT weren't involved. :(
Later: Just struck me, I had a PPP session loss early this morning, no loss of sync. I wonder if it's related to BT's work?
Tanzanite
My speed is fine (Dorset)
Aaron
Got bad pings to wow. East Sussex, South East england:
Tracing route to 80-239-149-47.customer.teliacarrier.com [80.239.149.47]
over a maximum of 10 hops:
  1    <1 ms    <1 ms    <1 ms  firewall [192.168.1.1]
  2   162 ms   178 ms   140 ms  telehouse-gw3.idnet.net [212.69.63.55]
  3   135 ms   145 ms   146 ms  w-s-1.lon1.arbinet.net [213.232.64.56]
  4   153 ms   156 ms   160 ms  Gi12-0.lon-wal-core-2.interoute.net [217.118.119.33]
  5   129 ms     *      115 ms  Gi0-0.lon-002-inter-2.interoute.net [84.233.152.186]
  6   140 ms   137 ms   129 ms  ldn-b1-link.telia.net [213.248.74.217]
  7   139 ms   123 ms   111 ms  ldn-bb2-pos1-2-0.telia.net [213.248.74.13]
  8   178 ms   181 ms   171 ms  ffm-bb2-link.telia.net [80.91.249.13]
  9   436 ms   150 ms   155 ms  ffm-b5-link.telia.net [80.91.249.241]
Quote from: Tanzy on May 03, 2007, 17:03:01
If I post you one end of an ethernet cable, Eve... :)
Tanzanite
lol would have to be one long cable!
Unfortunately, it would rather exceed the 100m segment that ethernet permits. :(
tomharrison
Just suffered a loss of PPP - Pings back to normal now and speeds back up to full :)
Tracing route to www.jolt.co.uk [82.133.85.65]
  1     2 ms     1 ms     1 ms  www.routerlogin.com [192.168.0.1]
  2    24 ms    23 ms    25 ms  telehouse-gw3.idnet.net [212.69.63.55]
  3    23 ms    25 ms    23 ms  g2-2-501.cr01.hx2.bb.pipex.net [193.203.5.14]
  4    24 ms    24 ms    23 ms  v3953.cr05.tn5.bb.pipex.net [62.72.137.29]
  5    25 ms    25 ms    25 ms  g1-1-6.ar01.tn5.bb.pipex.net [62.72.140.142]
  6    23 ms    29 ms    24 ms  ge-0-0-0-3801.jolt-gw.cust.pipex.net [212.241.24
1.14]
  7    24 ms    24 ms    24 ms  secure.jolt.co.uk [82.133.85.65]
Trace complete.
Thanks IDNet!
Tom
IDNet Home Max
Pinging www.bbc.net.uk [212.58.224.121] with 32 bytes of data:
Reply from 212.58.224.121: bytes=32 time=26ms TTL=251
Reply from 212.58.224.121: bytes=32 time=20ms TTL=251
Reply from 212.58.224.121: bytes=32 time=22ms TTL=251
Reply from 212.58.224.121: bytes=32 time=24ms TTL=251
Reply from 212.58.224.121: bytes=32 time=57ms TTL=251
Reply from 212.58.224.121: bytes=32 time=21ms TTL=251
Reply from 212.58.224.121: bytes=32 time=59ms TTL=251
Reply from 212.58.224.121: bytes=32 time=72ms TTL=251
Reply from 212.58.224.121: bytes=32 time=83ms TTL=251
Reply from 212.58.224.121: bytes=32 time=29ms TTL=251
Reply from 212.58.224.121: bytes=32 time=41ms TTL=251
Reply from 212.58.224.121: bytes=32 time=42ms TTL=251
Ping statistics for 212.58.224.121:
    Minimum = 20ms, Maximum = 83ms, Average = 34ms
Reply from 212.69.36.10: bytes=32 time=24ms TTL=61
Reply from 212.69.36.10: bytes=32 time=21ms TTL=61
Reply from 212.69.36.10: bytes=32 time=22ms TTL=61
Reply from 212.69.36.10: bytes=32 time=23ms TTL=61
Reply from 212.69.36.10: bytes=32 time=29ms TTL=61
Reply from 212.69.36.10: bytes=32 time=20ms TTL=61
Reply from 212.69.36.10: bytes=32 time=26ms TTL=61
Reply from 212.69.36.10: bytes=32 time=37ms TTL=61
Reply from 212.69.36.10: bytes=32 time=35ms TTL=61
Reply from 212.69.36.10: bytes=32 time=38ms TTL=61
Reply from 212.69.36.10: bytes=32 time=27ms TTL=61
Reply from 212.69.36.10: bytes=32 time=25ms TTL=61
    Minimum = 20ms, Maximum = 38ms, Average = 26ms
Namesco 2416/382
Apart from the few spikes in pings, normal all round.
Thanks, Simon, Miriam et al. :)
Mine are also back to normal, after a re-sync. Another Thanks to IDNet for the quick response and resolution.
Welcome to the forum, Tom!
Where are my manners? Welcome from me too, Tom. :)
Tanzanite
Quote from: rikbean on May 03, 2007, 17:39:25
Standing in the corner with the lights off  :laugh: Sorry, couldn't resist!
Waves hello  ;D
Also required a re sync but now speeds back and better than normal 4320kb/s :)
Good news. :)
I have to say that this thread is a good example of the way this forum can work for us all. By concentrating all the posts in one place, it's given us a chance to inform IDNet without overloading them with calls and emails, and it's allowed them to quickly find and fix the problem.
Congratulations to everyone for the work. Great team effort!
All other ISP's please take note of the way things should be done. ;D
Philip
conversation between me and my daughter, when I got home from work
meg: dad, internets knackered
me: oh heck
meg: can't get on msn
I check router, red light on
me: did you reboot the router?
meg: no
me: twit
I reboot router
me: it's working
meg: yay!
I check Idnetters
me: found the problem, it was BT's fault
meg: idiots
anyway, thanks to all at Idnet for sorting it out, and Idnetters for keeping us informed  :)
