FFTC suitable multi WAN routers
Started by davidthornton, Dec 31, 2010, 09:45:29
davidthornton
I had my FTTC installed yesterday. Would love to post my stats screenshot from the BT checker, but need to make 2 more posts to be able to do so.  ;D
davidthornton
Quote from: Rik on Dec 31, 2010, 09:46:01
So reply to this. ;D :welc: :karma:
Thanks. I didn't want to appear to spam!
davidthornton
davidthornton
These are my results attached. I am quite close to the Fibre cabinet. Perhaps 30 metres. The Openreach engineer did the test with his equipment from the master socket and showed me results showing pretty much full speed both up and down. He told me that other lines he'd installed had shown less favourable results than mine. Unfortunately my download speed is quite low.
It is, isn't it, I wonder why?
 :welc: :karma: David
What's the connection from the VDSL modem , i.e router and PC connection, cable or wireless.
davidthornton
Quote from: Steve on Dec 31, 2010, 10:41:55
I've got the modem connecting into port 1 of a Draytek 3300V 4 WAN port router. The LAN side of that connects into a Gigabit Ethernet switch which has this computer connected into it, that I ran the speed test from. Wireless is separate access points. There is a chance that it could be the Draytek 3300V throughput but I also have Virgin Media 50Mbit here and can usually get better speeds from that through port 2 on the same 3300V router (I've even had the full 50Mbit out of it through this router, but I am waiting to have a VM Engineer come and adjust the power settings here as it's not performing optimally either at the moment).
The speed test I did this morning is slower than other speed tests I can do via BBmax or Speedtest.net.
I have considered connecting the VDSL modem directly into a laptop and making a dial up PPoE connection to it to see if that improved.
I suppose the direct PPPOE will rule out the router but as you say it has shown with VM it can do the job, BT will be up to no good somewhere along the path.
Quote from: davidthornton on Dec 31, 2010, 11:01:38
It would be worth a try.
Indeed. Some Netgear routers have been shown up by FTTC as not being fast enough but not other makes as far as I know (yet).
Quote from: davidthornton on Dec 31, 2010, 10:08:30
Believe me, David, you wouldn't have had the chance with Rik the Spam Rottweiler at the door!  ;D
:welc: :karma:
davidthornton
I managed to make a PPoE dialup connection directly to IDnet FTTC, from a 10/100 FE port on a laptop running Windows XP Professional. I have attached the results. As you can see, they are substantially better than when I go through the router. I've also tested my Virgin Media 50Mbit connection, by DHCPing the cablemodem directly from the same laptop. The speeds were near perfect. I can therefore only conclude that the Draytek 3300V router I have has a throughput ceiling. This is slightly strange because I know I have, in the past, achieved 50Mbit from Virgin Media through this router on WAN port 2. I've looked through the settings but I cannot see anything that would be restricting things. I am currently trying to find out more about the capabilities of my 3300V (which is several years old and has no GE ports on it). However I've noticed that this new 4 WAN port router should be out in February. It supports 150Mbit throughput, so I am probably going to purchase it.
I am very, very pleased with FTTC vs the previous LLU ADSL2+ I had. The telephone exchange where I live is several kilometers away. The FTTC and copper cabinet are very close. I noticed that nobody seems to have achieved an upload speed above 8Mbit, so I am wondering if OpenReach are enforcing a limit at about that? Also, does anyknow know if it would be possible to bond two IDnet FTTC connections or is that not possible because it is not a LLU product and IDnet do not have equipment in my exchange; just OpenReach?
Thanks.
Afak, IDNet don't offer bonding, David.
Don't think any ISP that uses BT for ADSL tails does apart from BT themselves of course
Quote from: pctech on Jan 03, 2011, 20:21:16
Only those who use BT as a fall back to when there is nothing in the exchange. IDNet use BT Wholesale exclusively (AFAIK). Where as the likes of O2 use their LLU equipment, and fall back to BT (but with insignificant bandwidth/services purchased it would appear) when there is no LLU.
kev445
Quote from: davidthornton on Jan 03, 2011, 05:39:51
Thanks.
We used to use the Draytek 3300v and things slowed down if we used PPPOE or shaping (shaping was the speed killer), without pppoe or shaping the router would max out at about 70Mbit, I believe having many firewall rules would also slow it down. I tend not to touch Draytek equipment anymore, we now use PFSense on a 40Mbit leased line, which works very well.
Holodene
Quote from: kev445 on Jan 04, 2011, 08:42:55
What sort of hardware is pfSense running on?
davidthornton
Quote from: Holodene on Jan 04, 2011, 20:48:56
I intended to ask similar, but you beat me to it. :)
I used to have an old PC running FreeBSD and two dual NICs do all my routing and DHCP. I remember editing pf.conf. :) I wanted to replace this with a solution that I could fit in 1-2U in my comms cabinet. It needed to be easily configurable, reliable and quiet. The Draytek 3300V, together with its FXO and FXS cards, seemed ideal at the time and for the most part it has been fine. However because the 3300V only has FE ports, and given Virgin Media will roll out 100Mbit by the summer, here, I know it's got be replaced at some point in 2011. My main requirements are the ability to accept three GE WAN connections (1 x PPoE, 1 x DHCP and a third which is currently a statically assigned ADSL2+) and allow me to decide which devices on my LAN use them, based on source IP or traffic type. I also want decent IPsec VPN support with good throughput when running with encrpyption. Any suggestions?
Did we slightly go off topic?!?
davidthornton
Quote from: .Griff. on Jan 05, 2011, 00:54:19
Yes. Perhaps the thread could be forked, so there's a seperate one for discussing FFTC suitable multi WAN routers?  :angel:
