speed tester...
Started by Baz, Feb 06, 2011, 09:53:24
...on BT now has a 'FTTC' button  and a 'FTTP' button
how long has that been on
It wasn't there the last time I used it, Baz.
I noticed it this morning, it wasn't there on Wednesday...
They've alse broke a bit of it- if I try to run it using Opera it says I haven't got Java installed! Oh yes I have >:(
It's OK on Safari though.
BT broke something, Bill? Surely not. ;D
It must have happened at some point in the last 24 hours as it wasn't there this time yesterday.
Does it use a larger download with the fibre setting have you noticed, Griff?
Quote from: Rik on Feb 06, 2011, 13:18:56
I'd love to answer your question Rik but...
Quote
FAQ
null
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
The options are FTTP or ADSL/FTTC, so not many people will be able to answer that!
Who's idea was it to roll out an update on the weekend when no one is in the office to fix any problems?  :whistle:
Perhaps they thought a Sunday was quiet so not too many users putting a strain on the system?
Weekends will be at least time-and-a-half, but I'm sure that's entirely coincidental :P
Quote from: Bill on Feb 06, 2011, 13:41:16
This is true. :)
At least one report that it's broken on Firefox/PC as well...
No surprise there then, Bill.  :shake:
Also a failure on IE (don't know which version)... but the other user is also on FTTC, no reports yet of failure on non-FTTC connections.
Odd, I can't believe even BT would break it on the most common browser around!!
Didn't it only work with IE in its early days? BT are probably testing with IE6 for that matter. ;)
Another failure (all these are in the Fibre forum on tbb) with Chrome... all on FTTC.
But it still works for me with Safari :dunno:
Maybe BT have switched to Macs, Bill. ;)
From Commodore PETs, you mean?  :P
A failure on ADSL2+ reported now, so it looks possible that BT have broken it properly. Again.
I like to see them do a thorough job. ;)
Yep down for me too. Not on FTTC or anything.
At least it gives a bit of variety... on my Mac:
Opera- complains there's no Java and fails if you try to run the test.
Camino- complains there's no Java but successfully completes the speedtest.
Safari- runs with nary a problem.
Go figure ;D
BrianM
Just tested BT Tester, working for me on OE. :o
Brian
Take care of all your memories. For you cannot relive them.
Careful, Brian, that means they're watching you. ;D
I guess its playing up again
Download speed achieved during the test was - 10788 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9740 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 24.36:27.62:48.03 (SBE:NBE:PBE)
I wish  ::)
I've tried to use the new and improved BT speed test site a number of times this week to log low throughput. The only result I got back was an error.
As if by magic, now my throughput is running at full tilt it completes the test ;D
Download speedachieved during the test was - 31090 Kbps
For your connection, the acceptable range of speedsis 12000-33865 Kbps .
IP Profile for your line is -33865 Kbps
2. Upstream Test: -provides background information.
   Upload Speed
   8136 Kbps
0 Kbps   10000 Kbps
Max Achievable Speed
>Upload speed achieved during the test was - 8136 Kbps
Upstream Rate IP profile on your line is - 10000 Kbps
