Dropping ADSL Max connection in MK
Started by pctech, Feb 10, 2011, 16:36:49
One for Rik I suppose really.
Before I raise an issue with Zen technical support have you noticed any drops on your Max modulated connection over the past few days?
Had quite a few over the past few days and WAN counter was last reset about four hours ago (PC was off at the time so no traffic going across the link apart from the usual background noise)
Two on the 3rd, one on the 5th, Mitch. I put it down to engineering work as on all occasions I re-connected at a higher speed.
Mine keeps going up and down so not sure whats going on.
Are you running Routerstats, Mitch.
no but might over the weekend as am off work.
It would be worth it, it often shows what's happening.
