IPv6 could make spam filtering more difficult
Started by pctech, Mar 08, 2011, 19:04:40
Perhaps people will move to whitelists instead of blacklists.
It's also going to present problems to forums in terms of preventing spammers.
nowster
All it means is that instead of blocking /24s or similar for IPv4, they'll be blocking /64s or similar for IPv6.
Allocations will either be /128 to single end user PCs, or /64 or bigger to individual customers. (Larger customers will probably get a /48.) Blacklists will continue to work just as they have to date. That none of the DNSBLs are currently designed to handle IPv6 is more of a problem. When there is proven need, undoubtedly they will.
I run an IPv6-reachable mail server (/128 allocation from Gandi, not a tunnel). It does SMTP with optional TLS, imaps, and the only way that email can be sent through it is using a login over SSL on the submission port. I use several IPv4 DNSBLs to block connections and a final classification of spam/ham using spamassassin. My widely known primary email address gets maybe one unfiltered spam a month, but I can't as easily filter my @debian.org mail which gets forwarded on from Debian's servers, so I get about three a week by that route.
I don't use greylisting (but that would work equally well for IPv6) as I found that it is a resource hog that doesn't get you that much more protection.
Up to two years ago, I ran an ISP for 14 years. I now work in a different field of computing.
Else some other safe system will be applied. Cachpa for mail? Would stop bots at least to some extent.
