Link speed
Started by .Griff., Mar 26, 2011, 12:40:33
Am I misunderstanding something here?
I've got a Linksys WRT320N Gigabit router connected via CAT6 to my PC. The Realtek network adapter is reporting it's speed set a 1Gbps full duplex yet in the networking section of WTM it shows the "link speed" as 100Mbps.
Is that correct? I assumed (maybe wrongly) that the link speed should show 1Gbps?!?
I would have thought it should, Griff. I wonder if there's a setting needed somewhere in Windows?
Problem solved. Sort of.
I swapped the Cat 6 cable for an old Cat5e cable I've had for years and sure enough the link speed now shows as 1Gbps. If swap back the "new" Cat 6 cable it goes back down to 100Mbps.
The exact opposite of what you'd expect.  :dunno:
Obviously not a very good cat 6 cable!
Ah, the art of British understatement.  ;D
Quote from: Lance on Mar 26, 2011, 16:12:54
Looks that way  >:(
Sounds like the wiring is defective.
esh
Cat 5e can indeed negotiate gigabit speeds, it is just not rated to sustain gigabit transfer rates. It's good enough for home and small business though in my experience! We've managed to push nearly 80MB/s over short cat5e with a non-encrypted protocol.
