file transfer
Started by Baz, May 30, 2011, 13:08:46
any decent software to transfer photos between phone and pc. wont be using it a great deal but just something straight forward and easy to use would be good
You haven't said what type of phone?!?
Obviously if it's an iPhone or Android device it's a hell of a lot easier than a 6 year old Nokia.
opps  sorry  ::)
its just a simple samsung tocco lite.  I cant find the disc that came with it at the moment but I think ive had samsung software before and it caused a bit bother on my system
Baz try this link - http://www.samsung.com/uk/support/mobilesoftwaremanual/mobilesoftwaremanual.do?page=MOBILE.SOFTWARE.MANUAL
You should see a tab for "New PC Studio". Apparently that's much better than the old software that came on the original disc.
ah yes  nice link thanks   :thumb:
armadillo
Not sure I understand the question. If the phone has a USB connection, no software is needed at all. If it has no physical connector, I can see no direct method. Software is not usually need to transfer between any USB device and Windows.
MisterW
If you just want to transfer photos then I believe you can set the tocco usb to 'mass storage' mode, then it should be recognised as a dsic drive by whatever OS you're using. Try here http://uk.answers.yahoo.com/question/index?qid=20091114114542AADr3Ui
I now remember why I didnt like that samsung software before....its a pile!!!!!!!!!!!!!!!
got it from the link above,installed and every time I run it, it checks for updates straight away,either finds some or not  :dunno:  doesnt say the outcome, then shuts down.
setting  as mass storage the phone just says insert memory card,as it would say.I just want to transfer from pc to phone and the other way round too   how hard can it be
Thanks for the help any way, i'll try again later. its not a major problem
:thumb:
MisterW
Inkblot
With my Android phone I use the 'USB Storage' method. Prior to that however I simply took the memory card out of the phone and put it into a card reader - doesn't get much simpler than that unless for some reason you cannot remove the memory card :)
Quote from: MisterW on May 30, 2011, 14:46:56
Bluetooth ?
yep   thats what I did, whipped my dongle out and blue toothed them over
Kindly refrain from whipping your dongle out in public, Baz.   :evil:
had to be done Simon   sorry  ::)
no damage was done
I use memory cards or "usb disk mode" with a usb card on most phones. Quick and simple. Not helpful for email syncing, but great for photos and music.
