Reading, loss of service
Started by Glenn, Jun 02, 2011, 21:00:26
Quote from: zappaDPJ on Jun 04, 2011, 16:04:22
Hopefully someone will correct me if I am wrong.
No need. :(
Quote from: gwidnet on Jun 04, 2011, 14:16:55
My connection emmoult exchange northampton has been losing sync every 60 seconds for the last hour I've emailed support  :'(
That's a local problem, between you and the exchange.
gazzthompson
Nets still out after like 24 hours and its a really bad ***** time as I'm having a bad weekend in my long distance relationship and I need some ***** internet bad
gwidnet
Quote from: Rik on Jun 04, 2011, 17:02:10
Ah I think I may have solved this problem at least  :slap: - fingers crossed yet again. The connection seemed to stabilise yesterday evening, and started disconnecting every minute or so again this morning.
I had moved the router from behind the TV to a window sill, which started getting direct sunlight again this morning, I've moved it off the window sill and so far the connection is stable again!
Its a black linksys so really was quite hot.
Time will tell.
best ever speedtest 01 11 2011:
