ITunes/Quicktime updates
Started by Ray, Jul 26, 2011, 15:38:51
I see there is another update out for Itunes, am I the only person who can't get these updates to install using the updater? this is the 3rd Itunes/Quicktime update that won't install on my MC unless I download and install the components separately.  :comp: :rant2:
It usually works for me, Ray, though I try to ignore them as much as possible.
Quote from: Rik on Jul 26, 2011, 15:47:26
I think I will do the same, Rik, I only use it occasionally to synch and update my Ipod, I prefer Windows Media Player if I want to play music on my PC. :)
You can tell we're PC users, can't you. ;D
FritzBox
Quote from: Ray on Jul 26, 2011, 15:54:53
Sharepod works for me Ray, think you still have to have that horrible bloatware installed tho
Never thought I'd say this about an Apple producct but I use iTunes for my music library/iPod management because it works better.
No problems updating for me on Windows 7.
Not had any problems myself.
I used to get the odd problem several versions back where it would install but not run. However, not had that or any other problem for a while.
