ADSL2+ regrade complete, no sync rate increase?
Started by TheDuke, Aug 27, 2011, 11:48:54
TheDuke
Hey
So my regrade to an ADSL2+ service completed on Thursday and I'm a bit concerned that I haven't seen an increase in sync rate on my router.  From what I've read elsewhere people who have re-graded see an increase in sync rate immediately and the IP Profile increases over the training period.
So what should I be expecting?
Ben
Current stats below:-
Downstream
Download speed achieved during the test was - 5842 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :7126 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 6286 Kbps
Upstream
Upload speed achieved during the test was - 741 Kbps
Upstream Rate IP profile on your line is - 888 Kbps
Router
Line Attenuation: (Down)44.5db (Up)24.4db
Noise Margin: (Down)5.4db (Up)9.8db
That looks weird, your upstream shows you have been switched, and with your attenuation I'd expect a better d/s sync speed. What router are you using?
TheDuke
It's a netgear DGND3300.
Some details below.
Firmware Version:  V2.1.00.48_1.00.48
ADSL Firmware Version: A2pB023k.d20k_rc2
http://www.netgear.co.uk/home/products/wirelessrouters/high-performance/DGND3300.aspx
And uptime
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA10394321394567028571005534:51:04
How's the router connected to the phone line, eg master socket, hard-wired extension, flying lead extension? What else is connected to the line?
Also which adsl modality is the router/modem using it should be ITU G.992.5 Annex M
TheDuke
The router connects straight to the master socket, there is some extension wiring from the master socket but only a phone is attached.  I'm using an adslnation nte5 faceplate.
Unfortunately the router EWS doesn't provide me with the modality information, I think i can enable telnet and get it though, will do that now.
Ben
Try removing the faceplate and plugging in to the test socket, Ben. Check your stats as soon as the router resyncs.
TheDuke
Heres the adsl stats from telnet hope it's what you were after. EDIT: BEFORE TEST SOCKET
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 888 Kbps, Downstream rate = 7126 Kbps
Link Power State: L0
Mode:                   ADSL2+
Channel:                Fast
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       5.5             10.0
Attn(dB):       44.5            24.4
Pwr(dBm):       0.0             12.7
Max(Kbps):      7964            888
Rate (Kbps):    7126            888
                        G.dmt framing
K:              223(0)          14
R:              16              16
S:              1               8
D:              32              8
                        ADSL2 framing
MSGc:           59              10
B:              222             13
M:              1               8
T:              1               9
R:              16              16
S:              0.9968          4.0000
L:              1918            256
D:              32              8
                        Counters
SF:             8907903         560182
SFErr:          4420            4294967264
RS:             579013696               2567094
RSCorr:         2806742         0
RSUnCorr:       79292           0
HEC:            4034            4294967285
OCD:            212             0
LCD:            0               0
Total Cells:    2425140631              50501
Data Cells:     30739184                62
Drop Cells:     14762
Bit Errors:     0               0
ES:             1434            0
SES:            16              0
UAS:            37              0
AS:             144302
INP:            1.06            2.00
PER:            16.19           18.00
delay:          7.97            8.00
OR:             32.10           7.11
Bitswap:        17495           3680
Total time = 1 days 16 hours 60 sec
SF  = 8907903
CRC = 4420
LOS = 0
LOF = 0
ES  = 1434
Latest 1 day time = 16 hours 60 sec
SF  = 3559410
CRC = 780
LOS = 0
LOF = 0
ES  = 291
Latest 15 minutes time = 60 sec
SF  = 3715
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 15 min 0 sec
SF  = 55602
CRC = 30
LOS = 0
LOF = 0
ES  = 11
Previous 1 day time = 24 hours 0 sec
SF  = 5348493
CRC = 3640
LOS = 0
LOF = 0
ES  = 1143
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 55539
CRC = 41
LOS = 0
LOF = 0
ES  = 16
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 55539
CRC = 50
LOS = 0
LOF = 0
ES  = 18
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 55540
CRC = 37
LOS = 0
LOF = 0
ES  = 15
Showtime Drop Reason:   8000
Last Retrain Reason:    8000
I wonder if BT have set the adsl2+ profile at adslmax, (but they don't usually do that without being asked), not sure how that would show up in the adsl info
TheDuke
Stats on the test socket.
ADSL Link Downstream Upstream
Connection Speed 7438 kbps 888 kbps
Line Attenuation 44.5 db 24.5 db
Noise Margin 6.2 db 11.4 db
Channel: FAST, Upstream rate = 888 Kbps, Downstream rate = 7438 Kbps
Mode:                   ADSL2+
Channel:                Fast
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):       6.2             11.4
Attn(dB):       44.5            24.5
Pwr(dBm):       0.0             12.9
Max(Kbps):      8940            888
Rate (Kbps):    7438            888
                        G.dmt framing
K:              233(0)          14
R:              16              16
S:              1               8
D:              32              8
                        ADSL2 framing
MSGc:           59              10
B:              232             13
M:              1               8
T:              1               9
R:              16              16
S:              0.9979          4.0000
L:              1996            256
D:              32              8
                        Counters
SF:             5380            4849
SFErr:          0               0
RS:             349708          87295
RSCorr:         142             0
RSUnCorr:       0               0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    1517386         1241086
Data Cells:     30814           34054
Drop Cells:     14762
Bit Errors:     0               3397
ES:             1446            0
SES:            17              119
UAS:            101             0
AS:             88
INP:            1.02            2.00
PER:            16.21           18.00
delay:          7.98            8.00
OR:             32.06           7.11
Bitswap:        6               0
Total time = 1 days 16 hours 12 min 27 sec
SF  = 8943436
CRC = 4910
LOS = 1
LOF = 9
ES  = 1446
Latest 1 day time = 16 hours 12 min 27 sec
SF  = 3594943
CRC = 1270
LOS = 1
LOF = 9
ES  = 303
Latest 15 minutes time = 12 min 27 sec
SF  = 39248
CRC = 490
LOS = 1
LOF = 9
ES  = 12
SF  = 55602
CRC = 30
LOS = 0
LOF = 0
ES  = 11
SF  = 5348493
CRC = 3640
LOS = 0
LOF = 0
ES  = 1143
SF  = 55539
CRC = 41
LOS = 0
LOF = 0
ES  = 16
SF  = 55539
CRC = 50
LOS = 0
LOF = 0
ES  = 18
SF  = 55540
CRC = 37
LOS = 0
LOF = 0
ES  = 15
It's almost as if BT have profiled the line to Max. This is one for support, I'm afraid, but they won't be able to do anything until Tuesday, when BT re-open.
TheDuke
Ok Thanks Rik and Steve, most helpful!  Will post the outcome here.
jezuk1
The router is reporting information for G.DMT and also ADSL2 framing - seems strange? Normally I would only expect to see ADSL2 framing information unless I am mistaken  :D
TheDuke
Yeah.. I don't pretend to understand half of whats in that status stuff, but it does say ADSL2+ at the top so I guess it's supposed to be that way.
I think that's why we are thinking the adsl2+ profile is set at adslmax. What I'm not sure is what you see if the adsl modality in the router/modem is set to G.DMT
Given your downstream attenuation your current sync speed looks spot on to me.
jezuk1
#18
Agree, the sync speed you have looks pretty much normal for your line length / attenuation. Assuming nothing is wrong with your line then I'd say it's about 3 to 3.5km in length (reference 1 below). If you look at the fancy graphs on the reference 2 you'll note that beyond about 3km the difference between ADSL and ADSL2 tends towards insignificance. You only really get a significant speed increase for lines less than 3km (or those <about 40db attenuation)
In summary - your ADSL2 sync speeds look entirely normal  :)
Reference 1:
http://whirlpool.net.au/wiki/dslam_speeds
Reference 2:
http://en.wikipedia.org/wiki/G.992.1
TheDuke
Yeah, looks about right after seeing the graphs.
Kitz certainly is in agreement regarding the current sync although suggests a gain over adslmax of around 1500Kbps.
http://www.kitz.co.uk/adsl/max_speed_calc.php
