Speedtest.net problem
Started by tehidyman, Sep 28, 2011, 08:22:54
tehidyman
Tried to use speedtest.net this morning.  Login details are saved by Firefox but site says they are incorrect.  Then says that my email address is not recognised, to allow me to reset it. All my past readings are stored there and I would prefer not to lose them by re-registering. Is it me or is it them?
Same here, looks like they have problems their end.
Ditto. There appears to a server-side issue.
[EDIT] In fact it appears that the server that holds the speed test data is off-line...
BrianM
No problem here. 1630.   Must have been fixed.
Brian
Take care of all your memories. For you cannot relive them.
tehidyman
Agreed- I've just logged in ( 16.32) as usual and everything seems back to normal.
Confirmed and I think I've just recorded my best ever result :yeay:
Maybe Griff's engineer has been round to check your line, Zap? ;)
