Outage?
Started by Reya, Oct 20, 2011, 13:31:55
My connection went down about 25 minutes ago & still no sign of getting it back. I've rebooted, powered down the router (Netgear DG834G) and still no joy.
All I have right now is my smartphone & dear old Virgin Mobile's so-called 3G service (which should be re-labelled SP: snail's pace, IMO). Can anyone with a faster connection (ie: everyone else in the world!) please let me know if there are any outages? Norfolk/Suffolk border here, if that helps.
Thanks everso :)
I can't see anything on AAISP or IDNet, maybe give support a call?
Also try putting your number in here http://status.zen.co.uk/broadband/ to check for detected faults
Thanks for that number, pctech. Turns out there's a fault at Ilford which is affecting me. I'll add that page to my phone's bookmarks :)
Fortunately although my area code is listed for the Illford fault, its not affecting my connection!
sparky
Funny. I have just had a loss of connection as well, not a re-synch, LCP just went down.
Tried the above link from my phone, but my number wasn't listed as affected by anything. Mine went down at 14:21 according to the router log. Phoned support, but they didn't know of any problem in my area, so power cycled my router, now up OK again.
What was strange was that I was listening to my DAB radio, at the time my broadband went, so did my DAB signal !
Localised power cut affecting exchange and transmitter?
I had a blip this evening, but it was over in about 10 seconds.  Internet light flashed, and went red on router, then came back again.  :dunno:
I just lost internet at 08:38am it just came back up. Support was...erm strange.... :o
sat_mad
Just had the same here, Gary, loss of PPP and CHAP timeouts when trying to reconnect.
Den
I lost internet at about 08.40 as well and its just come back up, All about the same times as Gary. Support? What support I could not get through and was on hold listening to music, but the message did say my call was important to them.  :slap:
Mr Music Man.
Quote from: Ray on Oct 21, 2011, 09:00:11
Thats it, Ray, called support and they asked what company I was? Then asked if my Firewall was turned off!
All I can tell you is that IDNet are aware of the problem and to reboot your router if you are not connected.
Quote from: Den on Oct 21, 2011, 09:01:14
I had the music, tbh Den when you got though it was painful  :(
JB
I had the same error. ADSL to the exchange was fine but the router was reporting 'authentication error'.
JB
Den
My broadband is running fine, when I logged onto the router it warns me that Intranet is turned off by default but the Intranet and Internet lights are flickering like mad  :dunno:
Mr Music Man.
Ardua
#18
My router logs show failed PPP negotiations throughout the night. Like others, I lost internet at 8.37am and by the time that I had got my BB out and loaded the AAISP fault page, the fault had been detected by AAISP's software. A 'soft' reset of my router has brought things back on line.
Edit:
AAISP now showing that the incident is CLOSED at 09.02am
Quote from: Ardua on Oct 21, 2011, 09:21:09
I wish IDNet has a page like AAIPS so we could see for ourselves the issues, in house so to speak.
sparky
rgthomas
No connection in Sevenoaks 01732 since 0840 hrs.
Turned router off for half hour, made no difference.
Still no connection at 1040. Just tried to login into router (Netgear DG834) , CHAP authentication failed.
rgthomas
Working again now, after going to router address http://192.168.0.1 and re-doing setup wizard, entering my IDNet login details.
I don't remember ever having to do this after an outage before.
From the network status feed:
All BT ADSL circuits affecting all our cutomers and many other ISPs failed at around 8:45 this morning. The cause is unknown at present. Service resumed at about 9:00. If your router has not automatically reconected please reboot it.
BT say that around 365,000 broadband customers were affected.
