Broadband Disconnecting Every Night - Low SNR - Is There Anything I Can Do?
Started by arobertson676, Nov 18, 2011, 21:38:51
arobertson676
As the title suggests, my connection is frequently dropping from a low SNR. I would really like to get this solved so any advice would be very much appreciated.
You could get BT via support to set your margin a notch higher obviously that's going to cost you in sync though, have any of the routers you've tried got the ability to adjust the downstream margin?
arobertson676
Quote from: Rik on Nov 19, 2011, 11:38:44
And have you tried at the test socket, if you have one?
I have tried the test socket and I get the same problems.
OK, that puts the noise outside your house, then. It's worth a call to support tomorrow and ask them to test the line.
