Microsoft planning to replace NTFS in Windows 8
Started by pctech, Jan 17, 2012, 20:13:32
Niall
Flickr Deviant art
Leo Tolstoy
esh
I'm sure you all miss FAT32, right? ;)
The joys of cross-linked files! Missing hard-drive space! Corrupted file tables...
Yeah, FAT32 needed replacing. I guess the question is, does NTFS? I've found it pretty good, especially with the journal system in Win7. Not a single corruption as of yet. I stupidly once plugged in a Win XP NTFS drive into a Win 2000 PC though and it thought the entire drive was corrupted, fixed it, and then all the files were gone. Urk.
Same here. Although I did antecedently delete a spare drive off of a "linked" drive portion table. Which ended up deleting the entire partition, not just the spare space. :(
But 3 days later I managed to rebuild the files and file tables. :)
Quote from: esh on Jan 20, 2012, 09:31:47
That sounds odd as Win2K was NT 5.0
It was the on disk format that was different in Win 2000 i.e. NTFSv3.0 . XP and onwards NTFSv3.1. The NTFS.sys driver in Win2000 was v5.0
Ah that explains it.
2000 had pretty much been and gone before I needed to know about that kind of stuff.
