Connection issues?
Started by psp83, Feb 01, 2012, 21:02:19
My FTTC connection went down about 8:25pm tonight, anyone else having problems?
The green DSL light is on, on the fttc modem but the internet light is orange on my router (7800n)
Quote
  Feb 01 20:56:32  daemon  pppd[604]: PPP: PPP Server No Response !!!
  Feb 01 20:56:32  daemon  pppd[604]: Doing disconnect
  Feb 01 20:56:35  daemon  pppd[604]: PPP: Start to connect ...
  Feb 01 20:56:58  daemon  pppd[604]: Couldn't get channel number: Transport endpoint is not connected
None of the staff are having any problems Paul. I assume you've tried a simple reboot?
Quote from: Lance on Feb 01, 2012, 21:07:22
Not yet, reboot of router and/or modem?
Modem I think, given it is that which is trying to negoitate the connection. However, doing the router first might sort it without having to upset the connection on the modem.
I powered both down by the mains, going to leave it of for 30 mins.
If that doesn't work I guess I will have to wait until the morning to get support to look at it.
Well I lied, I only waited 10 mins  :laugh:
Its working now, it must of been a problem between router & modem as tbb graph didn't show any disconnects.
I've had that a couple of times lately but usually a bit later in the evening i.e. 2300 . Modem always shows 3 green lights and router says connecting. I tend to leave the modem alone, rebooting the router for me doesn't seem to make much difference as to whether it will or it won't establish a connection. I blame BT. >:D
The PPPOE session would surely have to be live for TBB BQM not to show a drop as the modem just passes the IP address onwards.
Ok, haha, maybe the tbb graph does show it. I was looking at the wrong one :laugh: :red:
The disconnect around 9:30pm last night was when I wall mounted the modem.
That's more like it, btw my engineer said that he was obliged to  wall mount the modem.
Quote from: Steve on Feb 01, 2012, 22:15:13
The one that installed mine just sat the modem on top my router covering the vents of the router.
I moved the modem and they was both red hot, so during the day I put some wooden blocks between the 2 so air could flow and both cooled down, now the modem is wall mounted there is no heat to it.
I have the newer modem.
I mounted the router above it on the wall in the end, it freed up a shelf for more junk.
Quote from: Steve on Feb 01, 2012, 22:27:08
That's my plan as well but I won't be doing that until I run new Cat6 cable around the house.
