Moving to IDNet...
Started by Wivelrod, Jun 12, 2007, 22:37:07
Wivelrod
Hello there!
I've just put a MAC request in with my ISP. I've found the service from them rather disappointing, especially since they began throttling connections or what ever it is.
I've been doing a fair bit of research on various ISPs and IDNet seems to fit my needs. My pre-dominant use for the net is gaming, mostly MMOGs. I apply to and play most MMOG Beta's. And I'm a keen amateur photographer and I sometimes upload very large prints (that no one ever buys :P).
So I'm looking for an ISP that has good reliability, decent latency (though I don't play many "twitch" games only so the best ping isn't totally necessary), that doesn't grind to a halt in the evening (when I'm most likely to be patching which ever mmo I'm currently addicted too!) and has a support line that is actually answered instead of either ringing for 30 minutes, stuck in a queue, or simply engaged! And because of the need to upload some large files to the net, a good upload speed.
I'm therefore considering the Home SuperMax service.
Anyway, enough about why...I have a couple of questions.
1. Is my above logic sound? :P
2. I've never migrated ISP before. How much downtime can I expect?
3. Where are all the whining complaints about IDNET...try as I might I cant find any! Is it a consipracy?
4. My real concern... With my current ISP I've seen speeds up to 650kb/s download on a sunday morning, which often drops to between 1 and 2 Mbit in the evenings. However, recently the speeds have been constantly below 1Mbit 24 hours a day. I suspect I may have a problem on the line. I've tried bouncing the router but all that did was drop the "connection speed" a couple of hundred kpps.
Current router stats - do they look reasonable?
Connection Speed
Downstream: 5984 kbps
Upstream: 448 kbps
Line Attenuation
Downstream: 43.0 db
Upstream: 25.0 db
Noise Margin
Downstream: 9.0 db
Upstream: 20.0 db
My exchange (THOK) is rated as Green, so it shouldn't be exchange congestion.
Being I've just requested a MAC (I'm leaving them regardless of this current issue anyway), I don't expect my ISP to give a rats hind quarters about my problem...I guess I've lost confidence in them. So I'm probably going to forget about this issue until I've moved to IDNET.
In the mean time, does this sound like a stuck profile? I've just tried the BT Speedtester and all it reports is my download is 821 kilo bits per second (Kbps), and no mention of what profile I'm on.
Am I right to sit tight until I've migrated? It's annoying, but I can live with it for now (after, I was on 64kpbs ISDN for years :P ). I mean, it only took 13 hours to download a new MMOG beta yesterday ;)
Thanks in advance - and btw, nice forums. They have definately contributed to my decision to move to IDNet :D
DaveH
I've just moved in here from, I suspect, the same ISP you are currently with.
I have been amazed at the consistently high speeds and reliability of my connection since I jumped ship. It's the best ISP I've come across, and I should know, I've followed a few! (Copyright Python (Monty) productions - Karma to the first person to name the movie)
And added to that the fact I am now paying £9 a month LESS than before for a service better by a factor of 10, I am a very happy bunny.
Come on in, the water's lovely!
God save us from those that believe in you.
Welcome to the forum, Wivelrod :)
Quote from: Wivelrod on Jun 12, 2007, 22:37:07
Looks good to me!
Home supermax has the higher upload speed which will make your photo uploads a little quicker.
With support, you normally get someone answer the phone within a few rings. They are all very knowledgeable and bend over backwards to help.
IDNet do not throttle, or in any other way restrict your line, so the slow downs you're currently experiencing should become a thing of the past.
Quote
How quickly can you change the login details in your router? :laugh:
Quote
You can't them because we are all happy with IDNet! You'll soon start complaining that you haven't got anything to complain about!
Quote
Connection Speed
Upstream: 448 kbps
Line Attenuation
Downstream: 43.0 db
Upstream: 25.0 db
Noise Margin
Downstream: 9.0 db
Upstream: 20.0 db
Well, you have a good sync, but there is an indication of a (possibly past) fault on the line as your noise margin has been increased to 9db (from the default 6db).
Quote
It could well be a stuck profile. Did you run the newer BT speedtester which should give you your profile?
Quote
That's a choice only you can make! But you can make it safe in the knowledge that once you're on IDNet that they will get a stuck profile cleared as quickly as BT can do it!
Quote
and btw, nice forums. They have definitely contributed to my decision to move to IDNet :D
Thanks! Glad we could help!
Welcome aboard Wivelrod. ;)
Welcome Wivelrod?  I have managed to get my son to migrate to IDNet from Plusnet after months of badgering.  He is a software developer and needs a reliable connection.  He has only been here a couple of days but already his speeds have increased, he is never knocked off line and he says that everything is working smoother, more consistantly and just a better experience all round.
His only problem now is to get his young son to stop waching streaming videos of hsi favourite cartoons, I don't think IDnet can help with that though. ::) ;D
They could, Cav - second account on second phone line.  ;D :out:
Wivelrod
Thanks all, really helpful indeed!
I'm pretty sure I used the correct link to the BT Speedtester (I got it from the excellent FAQ post at the top of this forum), yet it didn't ask for any user name credentials despite the front page saying it would after entering my Phone Number and hitting GO. The results page merely gave me a download speed, some "acceptable" download speeds for different ADSL connections and instructions to log out and change my modem to use my ISPs account.
Basically it looked like I had the correct initial page but was being directed to the old results page after running the test.
Awaiting my MAC eagerly  8)
Odd. Are you with an unbundled supplier at the moment? Unless it was having a bad hair day, the tester should have asked for your login details. But then, it does come from BT. :)
Welcome to the forum.
I wonder if the issue of people being redirected to the old speedtester has come up again?
It's always possible, Lance, I'll go and see if it will talk to me...
It's working normally:
    IP profile for your line is - 2500 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  3200 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 2318 kbps
I only post the result so that people can feel sorry for me. :)
Wivelrod
Quote from: Rik on Jun 13, 2007, 11:46:14
Nope, my exchange isn't LLU'd yet.
I'll try again tonight after clearing browser cache and see if there's a difference.
Thanks for the welcome :)
Happy hunting. :) The BT tester usually works best first thing in the morning, if you can check then.
Quote from: Rik on Jun 13, 2007, 11:56:25
    Actual IP throughput achieved during the test was - 5315 kbps
;D ;D
That throughput is low for your profile. I think you need to tweak!!  ;D
Quote from: Rik on Jun 13, 2007, 12:49:39
I know Rik, it is just as it comes, but you know I am one of these " If it aint broke " types..  ;)
Looking at the throughput, though, I'd say it was broke. Mind you, I'd be happy enough with that speed!  :'(
Quote from: Rik on Jun 13, 2007, 12:53:13
Nah, it's fine for my needs, you are just a tinker at heart. ;D
Actually it usually shows up a bit higher than that, but it is fine at that. ;)
Kheldar
i'm a new customer to about a month ago after a horrendous time with a colour company....
seems great so far and the forums rock  ;D
i'll post mine later Rik and you can damn feel even sorrier for me  ;)
It will be nice to see a line that is worse than mine!  ;)
Quote from: Inactive on Jun 13, 2007, 12:59:43
It's the Celtic blood...  ;)
Kheldar
Quote from: Rik on Jun 13, 2007, 13:40:59
i cant agree more and i look forward to seeing one  :o
Wivelrod
 :o
I applied for my MAC last night...and it arrived this afternoon. They seem eager to get rid of me  ;D
Home SuperMax ordered!
Great news, we look forward to having you on board. Have a karma to celebrate.  :)
Kheldar
try this for size....
ADSL Link Downstream Upstream
Connection Speed 1920 kbps 448 kbps
Line Attenuation 51 db 15.5 db
Noise Margin 2147483647 db 24 db
