accessing 2700 settings
Started by Den, Mar 15, 2012, 17:37:50
Is the output from ipconfig /all as clear as the output from a tracert? I don't think it is.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Glenn>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : AMD
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . :
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::a1ef:9bf9:b9dd:c803%13(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.11.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 17 March 2012 09:28:14
   Lease Expires . . . . . . . . . . : 19 March 2012 09:28:14
   Default Gateway . . . . . . . . . : 192.168.11.1
   DHCP Server . . . . . . . . . . . : 192.168.11.1
   DHCPv6 IAID . . . . . . . . . . . : 292315757
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-33-65-5B-00-13-72-9F-24-BA
   DNS Servers . . . . . . . . . . . : 192.168.11.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
The address in bold is what you are looking for.
#27
I don't think it's quicker to find the 17th entry in a list rather than the top one, but everyone to their own.
Quote from: FritzBox on Mar 17, 2012, 09:25:26
Wouldn't "cmd" then typing "ipconfig /all"      be the simplest way to give him the Default Gateway?
Quote from: Steve on Mar 17, 2012, 09:27:45
I agree, surely it's not that difficult to get a DOS prompt in Windows 7.
The search box does not parse command line entries into the cmd box
Den
My default Gateway is   192.168.1.254       when I type it in to IE9  it goes to the page telling me that it cannot be accessed. Following the instuctions it tells me to check via tools/advanced that SSL and TLS are ticked. SSL 3  and  TLS 1 are ticked but non of the others, is this correct?
Mr Music Man.
just checked mine and it isn't running in a secure session.
FritzBox
Factory reset is sounding good at the mo
Den
But that does not explain why it seemed to still work in Firefox after it stopped in IE9 and then later stopped with all other browsers.
Mr Music Man.
Delete your existing network connection and create a new one, that will clear out any rogue settings
Den
I left it until this morning to try to fix the problem. Unplugged the power for 5 mins, powered up again and it now works OK. I think that is called the Microsoft Cure  :eyebrow:
Mr Music Man.
Quote from: Den on Mar 25, 2012, 09:59:18
I have a similar issue with a Netgear, though on Vista. After about a week, there is no way to access to router homepage unless I reboot the router, and then back to the same cycle; everything else loads normally. Sometimes it will still load on one browser but not another for one or two times, then fails.
