WNR1000 loopback issue and fix?
Started by andrue, May 02, 2012, 20:33:28
Ten minutes ago my laptop stopped connecting to my mail server. I thought I'd tracked it down and come up with a workaround but now I'm just confused.
I thought it was because my WNR1000 was not providing loopback facilities. I could connect to my server using the internal network address but not the domain name. I was a bit puzzled as to why it should be a problem a week after my connection went live and I switched to this router. Anyway I decided to try setting up a static route. That allowed me to connect using the domain name but apparently I was connecting on my external address. So I disabled the static route and it's still working.
I've done some Googling and the WNR1000 supposedly doesn't support loopback. The questions therefore are:
a)Does it?
b)If it doesn't then why did it take a week before it caused me a problem?
c)Did my static route fix something? For how long?
d)What the bleep just happened?
BTW:I did reasonable due diligence and my internet connection was up. TBBQM doesn't show a break either so presumably the router didn't reboot.
Any thoughts?
Sorry I know very little about networks Andrue, but logically data is being cached somewhere. I also know very little about ARP but may be worth a read.
http://www.tildefrugal.net/tech/arp.php
Quote from: Steve on May 02, 2012, 21:16:09
Thanks for that link, Steve. An informative read although I don't think it helped me. Everything seemed fine again this morning so for now it's just a weird glitch.
:dunno:
