netgear dg834g V5
Started by sobranie, May 12, 2012, 11:08:11
Help please .... urgent.
How does one factory reset subject router?  Eg; no pin hole on back!!!
Restoring the Default Configuration and Password
This section explains how to restore the factory default configuration settings, changing the
router's administration password to password and the IP address to 192.168.0.1. You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function (see "Backing Up, Restoring, or Erasing Your Settings" on page 4-1).
• Press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
Use this method for cases when the administration password or IP address is not known.
http://www.downloads.netgear.com/files/DG834Gv5_UM_11Mar10.pdf
