BT 2701 HGV-C Big problem :(
Started by Bazru, May 14, 2012, 09:34:57
Bazru
Hi to All!
I have BT2701HGV-C
4201-003004-001
I have upgraded its to Qwest QT04-6.1.5.48.2 firmware
Now I cannot use options page...
I specify IP 192.168.0.1. Or 192.168.1.254 , but options page does not open.
The modem connect with PC via WIFI or LAN cable, and PC receives IP address from the modem 192.168.1.66
What it is possible to make?
Really it is necessary to throw out absolutely new modem?
Den
This happened to me a couple of months ago, it cleared and worked fine after turning the power off for 5mins and then powering up again.  :fingers:
Mr Music Man.
Bazru
Quote from: Den on May 14, 2012, 09:56:03
Has not helped :(
The modem connect with PC, but the page of options does not open.
Possibly it is an new (unlocked) firmware problem. How to return an old firmware (factory shipped firmware v6.3.9.41-plus.tm) ???
Look for the reset switch on the back and hold it in with straightened paper clip for about 10 seconds.
Bazru
Quote from: pctech on May 14, 2012, 10:37:02
Quote from: Glenn on May 14, 2012, 10:43:56
http://bt2700hgv.tripod.com/085.htm
Try home/support/utilities
Not helped :(
In your windows connection details or ipconfig /all what IP does the 'default gateway' have? Maybe try that?
Polchraine
You now have a door stop ...    There are warnings about changing BT 6.3.xx.xx firmware to Qwest but you may well have ignored them
http://bt2700hgv.tripod.com/085.htm   It is there in bright red.
Bazru
Quote from: Polchraine on May 14, 2012, 12:51:59
I have read it. already too late that either change. But already I have made it.
How now to restore old Firmware?
Your IP is in the 192.168.1.XXX range and so the router must be in that range too.
Does "Home" or "Gateway" get you to the rounter page ?
you have tried 192.168.1.254, so try 192.168.1.0 , 192.168.1.1 and 192.168.1.253.
I upped a BT v5.29.107.12 recovery to this F/W and then downgraded it back using the usual routine without any problems. Try each of the v6's in turn.
Bazru
Quote from: kinmel on May 14, 2012, 15:17:04
Has helped nothing :(
The modem on the former connecting with РС - a range of 192.168.1.XXX addresses
But the page of options is inaccessible.
I seem have spoilt the modem. How it is possible to restore a factory firmware?
Polchraine
Quote from: Bazru on May 15, 2012, 14:12:38
You could try the recovery firmware that is linked to, but the chances are you will be unsuccessful.   You have nothing to lose but trying though.
Bazru
Quote from: Polchraine on May 15, 2012, 15:44:10
where can I get this program?
Bazru
Tried this?  Do NOT use this Qwest v6.1 firmware to downgrade a BT 2700HGV or 2701HGV-C which has newer v6.3.x firmware – it will semi-brick the hub rendering it unusable. I suspect other 2700/2701 models with firmware higher than v6.1 may also be bricked in similar manner. You could try downgrading first to BT v6.1.1.22 (17MB file) and then reflashing to the Qwest firmware.
Bazru
Quote from: Glenn on May 15, 2012, 17:32:19
What can I do now? Just throw a modem? No variants?
If you have tried everything and it still doesn't work, then there isn't much else you can do.
Bazru
Certainly the BT has a programme of recovery firmware. Where to find it?
No idea, read through the Tripod website it may help.
Quote from: Bazru on May 15, 2012, 18:34:08
Which BT firmware do you want to try ?
You will need to locate the router's upgrade page to use any of them though
Polchraine
If you ever think of becoming a builder - you will at least have some stock to start off with!.
Bazru
Quote from: kinmel on May 15, 2012, 20:30:31
I've seen similar programs for BT Home Hub 1.5. These programs do not require an update page.
Quote from: Bazru on May 17, 2012, 05:26:55
Don't they run on the JTags though ?
Bazru
Quote from: kinmel on May 17, 2012, 07:12:32
They work without JTAG.
I restored with this program Home Hub v. 1.5
They are intended for restoring of factory BT firmware
