Any known issues in Hitchin (LLU) ?
Started by jezuk1, May 26, 2012, 12:16:47
jezuk1
Is anybody experiencing issues this morning with LLU DSL in Hitchin? My connection has been going up and down for the past couple of hours.
I contacted support but I don't really like to disturb on the weekend.
(trying to post this message in the short time when the router is synchronised!)
Relevant syslog data:
May 26 11:13:12 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: ADSL link down
May 26 11:13:13 dsl-7800n.home.gateway   dsl-7800n syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
May 26 11:13:14 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: xDSL G.994 training
May 26 11:13:15 dsl-7800n.home.gateway   dsl-7800n pppd[549]: Terminating connection due to link down.
May 26 11:13:25 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: ADSL G.992 started
May 26 11:13:29 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: ADSL G.992 channel analysis
May 26 11:13:36 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: ADSL G.992 message exchange
May 26 11:13:37 dsl-7800n.home.gateway   dsl-7800n kernel: Line 0: ADSL link down
(repeat...)
Nothing I can see covering that area.
jezuk1
I left the router while I went to work, just got home now and I can see from the log things appeared to stabilise mid afternoon so perhaps this was some issue at the local exchange.
That said, I am concerned my line has developed some noise. I went to buy a handset today so I could listen to the line (believe it or not I didn't even have one) and there was some clearly audible scratching sounds on a random intermittent basis although I couldn't link this to the DSL dropping, the audible noise and the DSL losing sync did not coincide.
Either way it's clearly not good to be hearing such noise on the line so I've booked an appointment for a BT engineer to come and sort that side of things out. Fortunately some scratching noise occurred while I was on the phone to the BT fault assistant and she agreed something wasn't right!
heres a handy site that was posted by pctech  :thumb:     when I had similar issues.
worth a look
http://status.bememberservices.com/
kiss of death to my self there.
start talking about this and I get a drop for about 40mins then again for 20mins   >:(
any one else?
and gone again as I type. have to say when thinking about it this seems like  a bad spell for drops recently,slow forums too...what's happening to the normally solid service we get
British Telecomilikeiitis?
Developed by other operators' equipment when placed in close proximity to BT's equipment, bit like how chicken pox spreads.
;D
jezuk1
The BT engineer changed the pair I am connected with between the road side box and the exchange. I'm seeing another ~1000kbps sync speed and almost no errors on the line now. Initial impressions are positive, looks like a big improvement. The old pair has been working but causing errors for all these years so I'm glad to see that one gone!
Before:
Line 0: ADSL link up, Path 0, us=1265, ds=16632
After:
Line 0: ADSL link up, Path 0, us=1295, ds=17717
