Finally I'm connected!
Started by Lance, Jun 22, 2012, 09:01:11
Had a 8am-1pm slot this morning. The BT Openreach guy phoned at 7:55am to say he was at the cabinet and was going to change me over to the new one.
A few minutes later he arrives at the house and within a few minutes the new faceplate is on the socket and the modem is out and booted up. A quick check by me that all is working is all that is needed, it is and so he is happy (probably because the first job of the day is done is 20 minutes).
Before he left, I got him to hook up his equipment to let me know the sync. It showed I'm getting maximum sync on my 80/20mb connection, happy days!
This is on a cable connection to my Bilion 7800n.
Good news, Lance.  Long may it last!  :thumb:
I only seem to be getting 7ms from a command prompt  ;D
Quote from: Lance on Jun 22, 2012, 10:08:54
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\zappaDPJ>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=8ms TTL=59
    Minimum = 8ms, Maximum = 8ms, Average = 8ms
C:\Users\zappaDPJ>
Damn it! ;D
Hey, its better than mine.
C:\Users\Paul>ping idnet.net
Reply from 212.69.36.10: bytes=32 time=17ms TTL=59
Reply from 212.69.36.10: bytes=32 time=18ms TTL=59
Reply from 212.69.36.10: bytes=32 time=16ms TTL=59
    Minimum = 16ms, Maximum = 18ms, Average = 17ms
My ping on FTTC is actually higher than ADSL2, on that I had 13ms ping  :(
Check it in 2 - 3 days time and see if interleaving gets applied, most FTTC connections have it applied automatically.
Don;t worry, I'll be keeping a close eye on it!
Ardua
Quote from: psp83 on Jun 22, 2012, 12:12:15
I upgraded to 80/20 (IDNet) over a month ago and whilst there is evidence in my router log of some interleaving I am getting a consistent Ping of 8 and actual speeds of 73.99/17.45. ;D
Quote from: Ardua on Jun 22, 2012, 17:13:53
You *#~£$£^%&*  ;D
