New Router Question
Started by sparky, Jul 12, 2012, 10:03:16
sparky
I know that peoples opinions vary, you only have to look at some of the comments on Amazon to see that, but I was hoping some of you techies on here might be able to offer me some advice.
Having "bricked" my trusty Netgear with a firmware upgrade and tried every suggestion that Netgear support could offer and every suggestion that i could get on the internet, time is money so to speak, I have now given up on it. I am currently using an old Speedtouch 585 V6 which gives me a less stable connection, but a a slightly better speed, which is good as far as I am concerned. I would prefer to buy myself a nice new router and keep this one as a backup. I am on a long line, my guess is about 3.5kms and it's prone to noise. I'd like the fastest connection that I could get, not necessarily the stable'ist, but obviously I don't want reconnects that often that it slugs my IP profile. These are my current stats:-
Uptime: 5 days, 15:17:20
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,064
Data Transferred (Sent/Received) [MB/MB]: 87.33 / 668.09
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 31.5 / 50.0
SN Margin (Up/Down) [dB]: 16.0 / 12.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 26 / 0
FEC Errors (Up/Down): 0 / 101,664
CRC Errors (Up/Down): 0 / 1,335
HEC Errors (Up/Down): 0 / 1,259
I have no more than about £80 to play with.  I have been looking at the Billion 7300n and the Netgear DGN2200. Has anyone got experience with either of these on long lines and/or offer any advice as to anything else that might be a better buy?
Thanks.
I used to run a Netgear DGN2200 without a problem on a shorter line so can't comment on performance on a longer line.
sparky
Is it still true that Broadcom chipset modems are better on longer lines?
Maybe that explains the extra few hundred kbs I am getting from my old Speedtouch 585 ?
FritzBox
#3
A V1 2700 with SBC firmware is great on a long line
If you could get hold of one of course
Guy selling some on fleabay. You would have to flash it yourself, and double check that that is the actual item
http://tinyurl.com/busvnas
sparky
Postage £18 !!  He's having a laugh isn't he   :laugh:
He's probably including the canoe costs. ;)
FritzBox
#6
Quote from: sparky on Jul 14, 2012, 13:18:41
Isn't he just. I used to send them Next Day Special Delivery in a separate box with padding for £9.50, when I used to flash them and sell them
FritzBox
sparky
Ok. There still seems to be plenty around.
I'm a bit confused about versions. If I were to go the 2700 HGV route, what specifically should I be looking for? Should I be asking or looking for particular assembly numbers or serial numbers etc?
This one is a bit more expensive, but it shows the serial numbers http://www.ebay.co.uk/itm/BT-2700HGV-54-Mbps-4-Port-10-100-Wireless-G-Router-2Wire-2700HGV-/320941288410?pt=UK_Computing_Wireless_Routers&hash=item4ab9976bda
Many thanks for the help.
FritzBox
As I said the V1 with SBC is the best
Although many users here found the BT fireware to be fine too.
