Disconnect
Started by psp83, Oct 06, 2012, 17:05:03
If I hit the disconnect button in my 7800 CP or just pull the ethernet cable out the back of the BTo modem, will that change my sync next time I plug it back in or reconnect?
Or will it simply just disconnect me from IDnet & Sync stay the same.
Silly question I know but I can't remember!  :laugh:
I'd say the latter, Paul.
Unless you remove and replace power from the modem or unplug the connector from the BT socket and plug it back in the modem will not renegotiate with the exchange.
