extreme FEC upload errors
Started by Glenn, Jan 02, 2013, 22:41:50
Not my line but my brothers, he is getting 128418.8148901181 per second according to his home hub, any ideas as to what could cause it?
Usual suspects I suppose noise/interference or if it stays at the same number could well be a 'bug'. Although saying that the upstream sync is a bit low with a healthy margin.
I've suggested the test socket already Steve, so I'll see what that brings.
Same problem from the test socket, he logged on to BT and it's showing a line fault..
That sounds promising if BT say there's a fault on the line? ;)
