Wiring routes
Started by tehidyman, Jan 22, 2013, 11:45:36
tehidyman
I have a Cat5e extension wired into the back of a filtered faceplate and ending in a filtered extension.  Will the BT engineer be able to use this cable wired into the back of the new fibre face plate to run to my Modem and Router where I have the power outlets.  I would like to do it this way to keep the cable run concealed and avoid drilling a hole through the wall.  BT chat could not help and searching only seems to cover straight forward set ups.
jm_paulin
Just curious...  My guess would be no,  as they will not take responsibility for it.  So what did they do?
tehidyman
Order not placed yet.  Still pondering. :-\
Polchraine
Quote from: tehidyman on Jan 22, 2013, 11:45:36
It will really depend on WHO you get.
You should get a new faceplate at the master.    That will have both filtered and unfiltered terminals on it.   Have the modem installed and tested at that point.
Then,   terminate the Cat5e on the faceplate - use one pair on the A&B unfiltered terminals and another pair on the voice 2&5 with a single wire on 3 (ring - if required).      At the extension,  get rid of the ADSL faceplate and fit a modular faceplate with a BT socket and an RJ11 socket.
That way there will be no arguments about who owns/did what and who is responsible.
tehidyman
Quote from: Polchraine on Mar 07, 2013, 09:25:32
Thanks for the advice.  Will file for when I make up my mind.
tehidyman
I am expecting the engineer to come next week and intend to follow your advice .  I am having a bit of a challenge to get a modular faceplate with the BT module and the RJ11 module from the same source. As a short term measure, if I only need broadband from the extension will the extension RJ11 socket be OK. As far as I can tell the RJ11 modules are described as ADSL and vDSL. I would then only wire from the A & B terminals on the faceplate in the first instance.
Polchraine
Quote from: tehidyman on May 12, 2013, 11:47:17
That should be fine ...     Run the A&B using a pair in Cat5e to the centre pins (3&4) of the RJ11 although depending on modem you may need to choose 2&5,  then connect another pair to 2 & 5 of the filtered faceplate along with a single to 3 ready for  telephony.  - As for the modules, they are a standard size so you could use them from different sources although they may look a little different in colour.
Not sure which supplier you are using but Clarity usually have both in stock.   http://www.clarity.it/xcart/home.php?cat=259
tehidyman
Quote from: Tacitus on May 13, 2013, 11:14:55
Thanks, just what I was looking for.
tehidyman
Quote from: jm_paulin on Mar 07, 2013, 07:42:00
The engineer has just left having completed the job here in about 15min.  The Clarity filtered faceplate on my BT master meant that he did not need to fit an interstitial plate and he left my faceplate untouched, including my Cat5e cable connection running to the extension. My existing filtered extension he used, plugging the modem in using my existing cable. A few quick checks and a speedtest 37.62Mb/s down and 8.99Mb/s up.  Then a friendly chat over tea and he was off to his next call. Thanks however to all replies to my queries.
colirv
Is that a 40/10 service? I didn't think IDNet offered that.
tehidyman
Quote from: colirv on Jun 18, 2013, 12:05:21
It is a 40/10 service but I moved ISP to get it. Now with BT
brian_idnet
Hi Colin,
FTTC services are availble where the exchange/cab has been updated by BT. details of our packages are here:
http://idnet.net/data_products/fttc.php
The Lite package is up to 38Mbps/2Mbps, the other packages are up to 76Mbps/19Mbps
Regards,
Brian
IDNet
colirv
Thanks, Brian. I'm actually on the FTTC Lite package at the moment, but the 25GB limit is nowhere near enough so, like tehidyman, I'll probably change ISP when my year runs out in December.
