Just joined IDNet from Pipex..........
Started by pn, Jul 11, 2006, 21:23:37
pn
...and at Pipex I had consistently 1.7 Mbps.
And now I have 1.1 Mbps on HomeMAX......
2 km from exchange.
Statistics                    Downstream              Upstream
Line Rate                   8128 Kbps                 448 Kbps
Noise Margin                 5.1 dB                    20.0 dB
Line Attenuation         27.5 dB                    19.0 dB
Output Power             19.7 dBm                 11.9 dBm
It certainly should not be any worse.
Hmmm.
P
Scott
First off....Welcome aboard ! We think you've made a good choice !
Secondly...it's early days for your new connection. While I'd hesitate to suggest you need to undergo the 10 day training period again I believe it's been confirmed elsewhere that migration from one Max provision to another can kick it off again.
It's a pain I know but hang in there...keep an eye on it and if in a few days it's still not showing any signs of recovering (or improving of course !) take advantage of IDNet's first-rate customer service. You won't be disappointed.
GL & HTH
Member of the IDNet Mafia
pn
Thanks for reply....
I have not migrated from a MAX service, just a 2 Mbit one.....and what's this trainign malarky all about ?
P
Scott
#3
AAahhhhh ! now I understand !
Here's a good post about it
GL & HTH
mrapoc
if u cba to look at that basically wait 10 days (of usual slow downs and connection drops) and after 10 days your top speed will be revealed to you  8) mine is 8mbps but i still get around 4mbps due to congestion  :-\
AvengerUK
Quote from: mrapoc on Jul 12, 2006, 16:29:45
*note: thats congestion due to his exchange, not IDnet*
mrapoc
Jeff
Welcome to IDNet pn :)
I take it we are on about throughput here as your linestats are perfect :)
What is the current VP congestion status of your exchange m8?
Try:
http://status.zensupport.co.uk/exchanges/
http://usertools.plus.net/exchanges/
Have you ever performed a BT Speedtest? This test disconnects you from IDNet and directly to BT. Basically, if you`re throughput is the same, fault is exchange congestion.
I`m pretty sure that your low throughput is due to BT training your line to determine what your Minimum Sync Rate is ;)
pn
Thanks for info....so will I only know my best speed once training has finished ???
Phil
Jeff
Read Lesley`s lowdown on this: http://www.kitz.co.uk/adsl/maxdsl2.htm Noone puts it better than her I reckon ;)
