Anyone else having problems tonight?
Started by andrue, Apr 12, 2013, 20:34:59
It's damn near impossible to browse. Even Google Earth seems to be shafted.
Edit it looks like it might be a general connectivity issue:
My modem says my connection has been up 1 day 16 hours (DLM put interleaving on yesterday morning).
Crus
I was having DNS problems a few minutes ago, and traceroutes were getting stuck in telehouse.
I restarted my router and all seems well again.
Doesn't look widespread:
http://craigswebsites.co.uk/ping/
But a couple of the IDnet FTTC graphs show the same glitch as mine.
Aaron
Having trouble with a lot of sites as well
I just lost web connectivity but didn't lose sync. I had to reconnect to fix.
I can only access the forum and idnet.net websites, everything else just hangs and doesn't load.
Quote from: lozcart on Apr 12, 2013, 20:49:23
That's the strange IDNet magic at work. I love that. :)
Now to get the rest of the UK working like it does!
Just checked on my phone using 3G and my Thinkbroadband graph shows the same blip, I'm going to try a router/modem reboot, I'll report back shortly  :fingers:
I'm back!!
The reboot has done the trick, so anyone else having problems its worth rebooting your router and or modem  :thumb:
I've just rebooted and things have improved, I wonder if a host link is playing up again although we should automatically fall over to the other one.
I thought things were a little slow earlier, but I seem to be browsing at normal speed now, without rebooting.  :dunno:
Same here. Sorry I missed the post, must have come up just before I clicked "post". :P
Clive
I experienced severe problems this morning when ten minutes into my session I kept getting "unable to connect to internet" messages.  All the lights on my Netgear router were lit correctly.  It took two reboots of the router before I could get back online.
Mine seems fine now. I didn't reboot anything. Just swore at my laptop - it knows I mean it  :evil:
Quote from: Technical Ben on Apr 12, 2013, 22:23:37
It was a close run thing, less than 2 minutes in it I think :)
I know its too late now and also I dont know where you all are or what system you use with IDNet but im on LLU and check this site for outages http://status.bememberservices.com/  click historic outages on the left hand side menu      hope it helps
