My little weekend project
Started by psp83, May 17, 2013, 18:55:43
So thought I'd treat myself for my birthday..
This is my little project for the weekend  ;D
Wish me luck!
Oh and does anyone know if you can use a windows 8 upgrade iso for a new install? If not, I will just clone the hard drive.
May the force be with you. And if that doesn't work there's always the option of a bigger hammer ;D
Quote from: Steve on May 17, 2013, 19:25:26
You should be OK http://lifehacker.com/5984278/how-to-do-a-clean-install-of-windows-8-with-an-upgrade-disc
Cheers, Waiting for my new hard drive to arrive, hopefully tomorrow, if not I will just stick the one in from this PC for now.
Quote from: zappaDPJ on May 17, 2013, 20:13:24
Hehe, I don't think I'll be using a hammer on parts nearly £1k worth  :laugh: there might be a few swear words though  ;D
Well it's up and working.
A little problem though, new Hard Drive was DOA :( so I will get a SSD instead of a mechanical drive..
But until then, I'm using the hard drive from the old PC but that's causing a few issues at the moment so I might reformat it and start fresh.
The i7 3770k is a 3.5 GHz with boost to 3.9 GHz but mines boosting to 4.2 GHz  ???
DOA  where you get that from and what sort is it
Quote from: Baz on May 18, 2013, 21:42:09
I bought the hard drive from dabs.com and it was a WD 1TB Black.
It will be RMA on Monday for a full refund.
There's a chance for mechanical drives being damaged in delivery, the box it arrived in looked like someone played football with it :(
Quote from: Simon on May 18, 2013, 23:17:10
Bloody couriers!   >:(
Yep, the box my motherboard, cpu and memory came in was also beaten up but luckily it was well padded inside.
