Network Problems?
Started by psp83, Jun 20, 2013, 12:55:17
I'm getting very slow speeds and packet loss
1. Best Effort Test:  -provides background information.
Download Speed
1.39 Mbps
0 Mbps   57.63 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.39 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-57.63 Mbps .
Additional Information:
IP Profile for your line is - 57.63 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
8.47 Mbps
0 Mbps   20 Mbps
Upload speed achieved during the test was - 8.47Mbps
Upstream Rate IP profile on your line is - 20 Mbps
sparkler
Support are looking into it  ;D
brian_idnet
Hi All,
I have asked the network guys to take a look at this and will report back shortly.
Regards,
Brian
IDNet
sparkler
mines returned to normal after reconnecting x3-4
Quote from: sparkler on Jun 20, 2013, 13:05:31
Speed has recovered but I don't think latency & packet loss has yet though.
Quote from: brian_idnet on Jun 20, 2013, 13:03:52
Hi All,
Regards,
Brian
IDNet
Thanks Brian.
Think I might call it an early day  :-\
brian_idnet
Hi,
We have checked across the network but it appears to have been a blip as all is testing ok now.
Regards,
Brian
IDNet
tKe
I'm still getting poor service. Latency seems fine but I'm seeing a large amount of packet loss and reduced throughput.
Quote from: brian_idnet on Jun 20, 2013, 13:29:53
Hi,
Regards,
Brian
IDNet
It seems to have started again Brian.
brian_idnet
Hi,
It might be worth giving your router a reboot to refresh the session.
Regards,
Brian
IDnet
I have the same TBB ping graph as psp83 - i.e. two sets of high latency spikes. Still happening here now.
Interestingly I monitor 3 separate IDNet lines with TBB. Two of them show this issue, the other doesn't....
brian_idnet
Thanks James,
I have asked them to take another look and will report back shortly.
Regards,
Brian
IDnet
Christopher
Having same probs,web pages slow to load and I can't even do a speed test as page won't load and I have rebooted my router.IDNet seem to be having these problems more often these days
Regards
Chris
Showing the same packet loss and latency spikes as everyone else. Rebooted the router and... I think I'll go and read a book  :-\
(The speedtest.net site took almost three minutes to load, before I could even do the test!)
tKe
The third reboot seemed to resolve it for me.
Christopher
Quote from: tKe on Jun 20, 2013, 13:55:55
Not for me,worse than dial up
Regards
Chris
I'm having the same problem here too.
It's been about 45 minutes now.
Quote from: jameshurrell on Jun 20, 2013, 13:49:56
When I compare a tracert from my connection (affected) to the other two IDNet connections I monitor, the difference is an extra hop to the non-affected connection.
So, the two affected connections are on the same gateway (gw4 if interested) whereas the non affected connection is on a different gateway (gw2).
Quote from: Christopher on Jun 20, 2013, 14:04:22
+1
I can't even stream BBC Radio 3 without a dropout every 10 seconds or so- 40KB/s is all it needs and I'm on fibre :(
Quote from: jameshurrell on Jun 20, 2013, 14:10:15
My login is @uk.idnet.dsl4, so I'm guessing that's the same as GW4.
Quote from: Bill on Jun 20, 2013, 14:17:58
+1
Everything going through my PC seems to max out at 35KB/s  :(
Doesn't always work I don't think as I have a gw5 login.
http://network-tools.com/default.asp?prog=trace - second last hop will show gateway.
brian_idnet
Hi All,
There appears to be an issue with one of our host links into BT, we have passed details onto them for further investigation. rebooting periodically may connect you to the fail over link and clear the issue. Further information will be posted to our network status page as soon as we have more.
Regards,
Brian
IDNet
