Your help needed
Started by Rik, Jul 11, 2007, 12:20:02
MoHux
Quote from: Rik on Jul 11, 2007, 14:56:17
Nothing you do at the software level, Mo, should affect your line, ie anything you do in XP will only affect the computer. Unless you disconnect or re-boot the router, you shouldn't be seeing any loss of sync.
That's the theory Rik ...... but I wondered if someone at IDNet might have seen all the re-boots, and tried to help??
Another thing I have wondered about recently is this;  Vista apparently insists on resetting the RWin and MTU dynamically, in a way BT is also resetting things dynamically, so when one changes something, the other reacts, and you get a see-saw effect between them!   Twisted logic??  Dunno ......  :-\ :-\
;D
Hi Mo
It should be impossible for BT or IDNet to see a re-boot of anything your side of the router, unless it causes the line to drop, and that shouldn't happen. I emphasise shouldn't... :)
RWIN/MTU settings should only affect traffic throughput. Although you have to re-boot the router to change its MTU setting, anything within Windows shouldn't affect the line.
You could always ask support if they can check whether you are showing a number of re-syncs.
drummer
D-link DSL-G604T
Upstream Rate   (Kbps)   448
Downstream Rate (Kbps)   7616
US Margin      23
DS Margin      6
Modulation      MMODE
LOS Errors      0
DS Line Attenuation   28
US Line Attenuation   32
Path Mode      Interleaved (Grr)
Profile 6500
789 meters from exchange
My sync was always 8128 before interleaving was switched on and I don't pretend to understand those figures as the only SNR I have any experience with is in the recording studio.
Coincidence maybe, but a quick glance appears to show those with D-link routers have interleaving on.  I know Miriam doesn't like D-link and I was wondering if some brands are more prone to LOS errors than others.
Thanks for that, Drummer. You can add a Netgear to those with interleaving on, but it's got a lot to do with my lousy line, I've never been in a position to try it on a good line. It's certainly true that some routers seem better at holding a line than others. The problem seems to be that, since Max, it's no longer possible to say that brand A is better than brand B. Now, the best results appear to come from matching the router chipset to that of the DSLAM you are connected to.
Noise margin is based on the same principle of signal-to-noise ratio that you are used to. The difference is that the margin is the amount of headroom the signal has over the point at which the router could not distinguish the signal from the background noise. This makes for a simple figure, where 0 is bad news (though, in practice, I find the Netgear holds the line down to -2db). Doing it that way does away with the need to know what ratio would be acceptable.
drummer
Quote from: Rik on Jul 11, 2007, 16:58:17Noise margin is based on the same principle of signal-to-noise ratio that you are used to. The difference is that the margin is the amount of headroom the signal has over the point at which the router could not distinguish the signal from the background noise. This makes for a simple figure, where 0 is bad news (though, in practice, I find the Netgear holds the line down to -2db). Doing it that way does away with the need to know what ratio would be acceptable.
Aaaaaah!  *Sound of penny dropping*
Thanks for that Rik as I've read up on it more times than I care to think and it always goes over my head (having dyscalculia doesn't help  :D ).
That must make life very hard for you, sorry to hear it. :(
drummer
Quote from: Rik on Jul 13, 2007, 09:07:45
My point was that your explanation worked for me, so thanks muchly and have a karma.  ;D
Frick my problem, it's one of those things.  Just that I'm used to knobs, faders, strobing LEDs and a pair of lugholes to obtain optimum SNR and ADSL is, how you say? a challenge.
Quote from: drummer on Jul 14, 2007, 04:56:12
Thank you kindly. :)
QuoteFrick my problem, it's one of those things.  Just that I'm used to knobs, faders, strobing LEDs and a pair of lugholes to obtain optimum SNR and ADSL is, how you say? a challenge.
ADSL was put on earth to frustrate and confuse us all - BT is its agent!  >:D
PhilFlyer
Quotebut it's got a lot to do with my lousy line
Sorry Rik but THATS not a lousy line.
THIS is a lousy line  :(
Uptime:   0 days, 7:52:11
Modulation:   G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:   448 / 224
Data Transferred (Sent/Received) [MB/MB]:   2.39 / 1.81
Output Power (Up/Down) [dBm]:   12.0 / 14.0
Line Attenuation (Up/Down) [dB]:   31.5 / 63.5
SN Margin (Up/Down) [dB]:   10.0 / 6.5
Vendor ID (Local/Remote):   TMMB / P
Loss of Framing (Local/Remote):   0 / 0
Loss of Signal (Local/Remote):   13 / 0
Loss of Power (Local/Remote):   0 / 0
Loss of Link (Remote):   0
Error Seconds (Local/Remote):   425 / 0
FEC Errors (Up/Down):   0 / 256,101
CRC Errors (Up/Down):   0 / 10,544
HEC Errors (Up/Down):   0 / 6,442
It normally synchs at around 1000k with a noise margin between 7 and 3. It has even managed to get on the 1mb profile for short periods but then large noise spikes bringing the synch rate down to around 500 - 700 at regular intervals. Today is the worst its been. All actions regarding wiring and master socket as recommended here and Thinkbroadband have been carried out.
Phil
That is a bad line, Phil, my sympathies and this somewhat worthless crown to wear. :(
I take it the line has been tested?
PhilFlyer
Hi Rik
I have spoken to IDNET a few times about this and they and BT have done tests - at one time BT said they had found and fixed a fault but nothing really changed.
IDNET have offered to have a BT engineer call but are concerned that they might declare the line out of limits for broadband and withdraw it. This would be  disaster so I don't really know what to do. ( I believe my line has already been marked unsuitable for a fixed 512k connection - even though I can normally sync at 1000k and a neighbour who is further than me from the exchange and whose lines go past my house has a perfectly working 512k connection !)
I have monitored my noise margin using Routerstats and there are huge spikes of noise during the day, usually starting fairly promptly at 6.30 am after a "quiet" night
The connection usually picks up after a few days and apparantly the current weather can have an adverse effect on overhead lines.
Phil
It's difficult to know what to advise, Phil. I think support are quite right to be wary of BT marking the line 'unfit'. Without a universal service obligation for ADSL, they can do that without you having any right of appeal. Are there any LLU operators in your exchange? That might be the only way to improve things though, tbh, I have a feeling the line is always going to be an issue unless BT replace it, and they aren't keen to do that sort of work.
If you notice any effect on the voice side because of wet weather, it would be worth reporting it via 151.
PhilFlyer
I don't know who else is in my exchange but as you say, it will be the same old poor line with presumably the same result. Can BT really just cut off BB with no appeal or do they just refuse to service it ? The voice side of my line is fine at the moment but yes, in the past I have complained at the slightest crackle in case they find anything that might improve the BB side.
Phil
Just possibly, Phil, you might get an improvement from LLU - but it's by no means certain. Unfortunately, if it didn't work out well and you decided to move back to BT, there's every chance BT would refuse to provision ADSL. BT have no obligation whatsoever to provide a broadband service, so they can withdraw it at any time without you having a right of appeal. :(
PhilFlyer
Thanks Rik - I think I will just wait for now and see what happens. Just after my last post I noticed my noise margin had gone up to 10db so a reboot has put me up to 640k.  This is how up and down it is all the time.
Unfortunately, Phil, in your situation all the normal advice is of no help. Other than going to something like a satellite solution, you don't really have a lot of options. Even if you paid BT to run new cables (and it would probably be painfully expensive given the length of line you are likely to have), there's little guarantee that it would improve your ADSL connection and, because there is no USO, there's no redress for you if it didn't. :( Is moving an option?
Afterthought: Take a look at this thread. It might just help you to try that router...
PhilFlyer
Thanks Rik
The BT 2700 router looks interesting but can't find it anywhere yet.
Phil
It seems to be an eBay item, as far as I can tell.
Quote from: Rik on Jul 15, 2007, 13:00:22
It is Rik, I havn't seen them anywhere else, they are commercial products made for BT industrial installs, as far as I can tell.
Thanks for the confirmation. Perhaps we should buy a bunch and resell them here? :)
PhilFlyer
Quote from: Rik on Jul 15, 2007, 13:29:50
Let me know if you do because I can't find one anywhere including Ebay
Phil
Plenty on eBay, put in 2Wire to search engine on networking.
Make sure it is the 2700 HGV model, not the 1800 model, and also that it is unlocked.
BTW, there is no guarantee that this will improve things for you, we are only going on feedback on here.
PhilFlyer
Inactive - found it, thanks for that - not a fortune at £40-50 but I will have to research this a bit more before I add yet another router to the collection of 3 that I have already.
Phil
You could always shift some of your old stock on eBay is this one does the job for you, though I always keep at least one spare myself. :)
Den
Hi Phil, The guy I bought my BT 2700HGV Hub off is selling on ebay at £41.99 plus postage. I found this seller to be very helpfull,responsive and quick. The router is superb. I live about two mile from my exchange and am now running without problems.  >:D
Mr Music Man.
