Secunia PSI
Started by Simon, Sep 20, 2013, 16:55:07
Does anyone here still use this, and is anyone having problems at the moment?  Mine (version 3.0) keeps complaining that there's no internet connection, but there quite evidently is.  I now have a grey icon where it should be green, and when I try to launch the program, it hangs on the 'Loading...' screen.
Mine works fine, but I can't seem to remove Python 2.7 from my PC, PSI complains that it needs upgrading.
Had a similar issue with PSI before, removing and reinstalling seemed to cure it.
May have to do that, Mitch, although, as it happens, this time it started up OK.  I wonder if there's a server issue their end?  The new version seems to have much less in the way of a UI, so it's difficult to tell whether it's actually working properly.
