More speed problems today
Started by davecollins, Oct 25, 2013, 12:05:59
Den you are now a Apple fan boy  ;) :evil:
#176
Quote from: Steve on Nov 06, 2013, 21:38:07
Funny thing is it's the same engineers whether it's BT, IDNet or Sky for FTTC.
Only for the wiry bits as far as the exchange.  Sky have their own national network of equipment, links and sub-contractors.  Their installs are done by non-BT subbies too.
As for Idnet, if there is a 5 day delay in getting new infrastructure, why did they not order it earlier?  Just in time supply only works if you understand what is happening in real time.
That's what I meant  Alan from 'home' to the exchange and your other point hindsight is a marvellous tool and only IDNet can explain why the situation was allowed to occur as we're still seeing packet loss over too weeks after Mavericks, which suggests to me although I might be way off the mark that capacity was borderline prior to that.
I don't think anyone understands why the packet loss is occurring, do they? IDNet hope the additional capacity (for want of any other explanation?) will cure it for the time being, so I gather.  ???
Quote from: kinmel on Nov 07, 2013, 09:29:21Just in time supply only works if you understand what is happening in real time.
I've never trusted that Justin Time bloke :D
talos
Could this packet loss be causing pages taking a long time to load ? I've cleaned out my comp Cookies etc and it still seem to take ages, more noticeable if I click off a pages and then try to get back on it straight away, most annoying  :mad:
It's not the cause this morning,although I've no idea of the current latency or throughput as on a mobile network.
colirv
Almost back to normal for my 40/2 today.
We've just recevied notification from BT that they executed our order a few minutes ago.
Great news. Thanks for the update Simon.
Excellent - I'm seeing full speed with no packet loss now. Fingers crossed that it continues.
Thanks for the update Simon, good news!
Teething probs maybe. I shot up to 75 a few hours ago and am now back down to 20 to 35.
Everything is fine here. My throughput is back to maximum and web pages are responding as expected again.
This is getting to be tiresome.
Adrian - your image was broken, but I'm also now seeing a big drop in speed and packet loss is back.
Come on idnet - what do we need to do to make you do something here??
It's Gawdawful here. The worst I've ever seen it  :bawl:
Edit: TBB speed test has just crapped out on me in disgust so I can't even post a graph  :eyebrow:
Edit 2: I can post a TBBQM graph though:
Strange, the image shows up here just fine. I even logged out and back in again.
Anyway, I am getting a bit fed up waiting for IDNet to fix this, it's been going on for too long.
Not good here either, generally sluggish too:
Ah. Speedtest.net was prepared to run all the way through. Probably the worst downstream result I've seen in over a decade:
So I've lost 91% of my downstream and about 15% of my upstream  :shake:
Not as bad as yours, but not good: :bawl:
Do you think BT might have subtracted some bandwidth insted of adding it? :dunno:
I just spoke to Idnet again. I've lost track of how many times I've called in the last month.
Yet again I'm being told to run bt speedtest. Yet again I'm being told that there don't seem to be many other users affected. Yet again I'm putting the phone down having no idea if anything will be done.
This really is appalling behaviour.
Sounds like it might be time to move on, which would be a shame because I quite like IDNet. Andrews and Arnold are now reasonably competitive, then there is always Plusnet...................... ;)
