Quote from: joe on Feb 18, 2014, 17:58:40
No, not what I was hoping for today. We'll have to wait until tomorrow to see if things are better.
You line seems to have constant packet loss spikes though, no one else so far seems to. I'm wondering if there is a local/hardware issue going on as well with your connection. Have you tried a different router to see of the constant red goes away, of is your exchange congested by any chance?
It's every half hour on the dot. So I doubt it's normal congestion. I wonder what would cause that? Perhaps a device on the network and/or local interference of a timed device/equipment? Perhaps a noisy electrical device, or someone uploading backups every half hour?
Router busy doing something else possibly!
I noticed on AAISP they have been geting SYN Flood attacks on ZyXELs routers, they say it is effecting other ISP's. "The issue is related to specific routers, and is affecting many ISPs. In our case it is almost entirely zyxel routers that are affected. It appears to be some sort of widespread and ongoing syn flood attack that is causing routers to crash and resulting in loss of sync" Their last attack was the 7th February.
Quote from: joe on Feb 19, 2014, 08:32:05
Mines a Fritz!Box 7390
Yeah I dom't think we need to all list our routers  :) but  with the link Technical Ben had had about certain Linskys routers and AAISP's saying for them its ZyXELs I was just wondering if this could be part of that pattern which AAISP say is effecting other ISP's.
SimonM_IDNet
Hi Gary,
I do believe the Zyxel issue was down to a vulnerability in certain router firmware/models and with remote management. The issue was usually solved by disabling that feature or locking it to one specific IP address (or by changing router of course).
Quote from: SimonM_IDNet on Feb 19, 2014, 09:12:12
Hi Gary,
Cheers Simon, same as the Linksys one. But since AAISP were getting SYN floods on the 7Th February stil, so could IDNet be getting them? As in yesterdays attack? Just wondered :)
Quote from: Simon_idnet on Feb 18, 2014, 16:48:53
Unfortunately the attck stopped before we were able to gather sufficaient data to identify the target. But we have identified the source vector so that if the attack recurs then we will have all the data needed to put a block on it.
All of the source traffic for the DDoS attack yesterday afternoon originated from AS4134, which is China Telecom. No surprise there! Just goes to show that  there are a lot of easily compromisable machines in China - hence that's where the DDoS traffic all comes from. However, the attacker controlling this stuff could be anywhere else in the world.
Quote from: Simon_idnet on Feb 19, 2014, 10:01:06
Thanks for the info, Simon.
Things are fine speed wise at the moment which is good.
Not just compromised. But setting up an attack with purchased hardware is theoretically cheaper too. So it's a target for criminals. A great example was when an entire Nintendo factory was setup. Except it was run by the mafia to both make cloned hardware at a profit, and launder money. You'd just not be able to cover such expenses in most over countries, let alone keep the illusion up long enough before you got caught.
So far so good:
Something odd about the upload, but there's reports on tbb about other people seeing that too so likely it's either tbb or BT.
BQMs are a bit cleaner too, tho' still a trace of the red stuff.
Trace of red on 3 of the 4 BQMs I can see too. Looks like the issue still isn't fully resolved.
More red stuff appearing.
Speeds back to cr*p.
Silly me, everyone's watching the curling on BBC Olympics.
Speeds are ok here
Download speed achieved during the test was - 67.4 Mbps
For your connection, the acceptable range of speed is 55.6 Mbps-69.5 Mbps .
Additional Information:
IP Profile for your line is - 69.5 Mbps
Speeds all over the place from minute to minute. I did get up to the 60's and now it's :
Nope now they are cr@p It felt like we were so close, speeds are up and down all over the place. I thought this week was the problem solved, and it really felt like it was today. This is very disheartening.
As have mine. Speeds in the afternoon awful as usual - not a blind bit of difference.
Quality:-
Speeds (62Mbps this morning as usual):-
Firefox:-
Chrome:-
and BT (attached)
My speeds are fine:
The BTw tester isn't feeling co-operative atm >:(
Quote from: Bill on Feb 19, 2014, 17:46:51
My speeds are fine:
They always tend to be getting on for 6pm again, bill. I have noticed since the DNS upgrade pages are loading very fast. Guess the more powerful equipment has done its job well there. Speed loss for me wasn't as bad today but its still not fixed.
Quote from: joe on Feb 19, 2014, 16:58:05
Quality:-
What happened at 4pm did you reboot your router?
No Gary I did not.  I am using the Fritz as base station to Fritz DECT phones which is one of its features, I will try detaching the phones to see if they are having any effect. I will then have to revert to the OR modem and linksys router I used previously to see if that is any different.
Doesn't alter the fact that everything was OK with my setup until recently. I an only suffering as others are and have in the past and since left iDNet.
