Netgear and OpenSSL
Started by Gary, Apr 13, 2014, 08:56:02
If any one wants to look at the source code for Netgear routers to see what version of OpenSSL you are running can go here.
http://kb.netgear.com/app/answers/detail/a_id/2649/~/open-source-code-for-programmers-%28gpl%29
Both Home and business users can check on this page. I checked a bunch of more recent ones and they are all safe. Netgear looks like they even on the most recent R7000 unit is only using version 0.9.8e. Hope that helps someone.
- R7000 (v1.2.164): OpenSSL 0.9.8e
- R6300v2 (v 1.0.2.86): OpenSSL 0.9.7f
- R6300v1 (v1.0.2.70): OpenSSL 0.9.7f
- R6250 (v.1.0.1.84): OpenSSL 0.9.8e
- R6200v2 (v1.0.1.18): OpenSSL 0.9.2b
- R6100 (v1.0.0.38): OpenSSL 0.9.8p
- WNDR4700 (v1.0.0.52): OpenSSL 0.9.8p & CyaSSL 1.6.5
- WNDR4500v2 (v1.0.0.42): OpenSSL 0.9.7f
- WNDR4300 (v1.0.1.60): CyaSSL 1.6.5
- WNDR3800 (v1.0.0.48): OpenSSL 0.9.8e
- WNDR3700v4 (v1.0.1.52): CyaSSL 1.4.1
- WNDR3700v3: Unable to Determine
- WNDR3700v2: Unable to Determine
- WNDRMACv2(v1.0.0.20): OpenSSL 0.9.8e
(It may be because it's late, I've had a busy week, and I've got a busier one ahead, and I just built a PC for a friend, so I've stats overload...)
But how do I use that list/info? I have a DG834G. Though I guess it's overdue for replacement.
Quote from: Technical Ben on Apr 13, 2014, 23:06:58
If you look though the source code it shows the version of OpenSSL used. To extract the source code from .tar you need something like WinRAR
