Android Antivirus
Started by sparky, Nov 04, 2014, 16:27:05
sparky
Being new to android, I was wondering what the consensus of opinion might be for installing an antivirus product on my phone, Nexus 5. I'm not going to be downloading games or installing loads of innocuous apps and won't be visiting dodgy web sites etc. Apps that I will use will may be some for News, Travel, Sport, Timetables etc. I have no plans to do banking on my mobile. Yes, I have two email accounts on it, both are spam filtered at the server. Yes, I suppose google playstore now has my paypal account details as it seems to be the only way to even get free apps.
Can't believe that anything more than something like the free avira app would be necessary, but is it even necessary ?  Any views?
Thanks.
nowster
I use BitDefender Mobile which has a free version.  I find it pretty inconspicuous, but you get a reassuring popup when it scans a new app.
Lookout for me , I paid a bit extra for the premium version as well. It appears to be fairly unobtrusive plus I get the backup facilities as well.
Avast Mobile Security for me...similar as what Simon said, it just sits there and works.Good SMS and Call filter too which I use a lot,app management if you want,Anti theft which seems good but I havent set up yet.
MisterW
+1 for Avast Mobile Security
J!ll
I have a new phone, and son said he will be putting Sophos on for me  :eyebrow: he started working for them about 3 weeks ago so has it free.
sparky
Thanks for all the inputs.
Baz, MisterW, is that the free version of Avast?
I thought I'd got it down to Eset or Webroot, Lookout is too expensive, minimalist if you take the free version. But have to admit, Avast looks good, although seems to require two apps to get the additional theft functionality. Is it not overly complicated? Is there any effect on battery use or speed of your devices? Seems to be exactly what you want if you have a rooted phone, but mine is not. Would you still recommend?
Cheers.
MisterW
QuoteBaz, MisterW, is that the free version of Avast?
Yes, but like Baz , I've never setup the Anit theft.
Doesn't seem to have any effect on battery life. I have it on my Moto G phone and Nexus 7 tab.
sparky
Thanks. Just what I wanted to hear.
I'll give it a go and see how it works out. Thanks for all the input.
talos
Don't set up the anti theft like I did, I found out too late that when you have it You cant get rid and it alters part of the phones set up  :mad:
MisterW
#12
Seems you can get rid of it BUT you need to remove it via Avast Mobile security. https://forum.avast.com/index.php?topic=126979.0
OR possibly this way
QuoteThis is way late I know, but I am posting for the benefit of anyone who might happen on this thread as I did.
I had to uninstall avast mobile security from my old android phone because it was slowing my phone down too much.  I forgot about the extra security it had installed when I first got mobile security. but here is what I found.
1)IF avast is installed through rooted, you can use the uninstall wizard,
2)f not, you have to uninstall the "disguised" app that installs with the unrooted install.  I understand that it gives a different name for each device on installation, or perhaps it has a set of names. In my case it was "rdp bridge"
since my device was unrooted at install (I waited until after warranty was over to root), I did not have the option of using the "uninstall wizard" that is "built in" to the app.
I had to"
1) uninstall avast through the app manager
2) uninstall the "disguised security app ("RDP bridge") through the app manager.
I assume you will have to know/remember the name it gives the hidden app to find it.
I chose to use titanium backup to uninstall.
This freed up my space and stopped the rest of the resource hogging that avast seems to do on my older device.
I hope this helps anyone who comes across this in the future.
J!ll
sparky
Quote
Oh Dear. I thought that Avast looked like it might get kind of complicated! Maybe Eset might be the better option.
MisterW
It isn't complicated, just don't setup the Anti theft.
colirv
I use AVG Antivirus Free. Seems fine.
I've had a read around the web , the Android operating system is very secure, which of course however doesn't excuse complacency . However don't forget it's in the interest of security companies to advertise their cross platform security software and ramp up the threats. iOS is not immune either but I suspect there's a very low install rate of security software on that platform.
So should you decide you need it, make sure it works as advertised and doesn't impair your smartphones performance.
http://phandroid.com/2014/05/06/android-virus-malware-scan/
sparky
Good article.
I think I might wait now until after the Lollipop upgrade as that seems imminent . Don't want too many problems all at the same time.
I think there's a lot to be said about careful smartphone use on the Internet negating the need for any security products, just depends on ones level of paranoia in the end.
