For the technically minded...my "proposed" upgrade
Started by AvengerUK, Aug 11, 2007, 03:06:17
AvengerUK
Hey all,
thought id run my idea for a upgrade to my current PC by you, as im not sure wether it all "fits together" or wether im getting compatable parts - ive never, as in, never, built a Intel machine - so i have no idea on sockets, motherboards or features. By just looking around, thus far ive come up with:
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield"
EVGA nForce 650i Ultra (Socket 775) PCI-Express DDR2 Motherboard (http://www.overclockers.co.uk/showproduct.php?prodid=MB-003-EA&groupid=701&catid=5&subcat=205)
BFG GeForce 8800 Ultra OC 768MB GDDR3 HDTV/Dual DVI
(http://www.overclockers.co.uk/showproduct.php?prodid=GX-049-BG&groupid=701&catid=56&subcat=877)
Also, im not sure wether my PSU is up to the job of all this, ive been told that it is, but its always good to be sure! (580W Hiper type-R)
mrapoc
Do yourself a massive favour mate and DO NOT buy from ocuk
http://www.overclock3d.net/articles.php?type=3&id=65&page=1&desc=overclockers_uk_-_swish_new_website__same_shoddy_service_
Review sums up what I and others have experienced wayyyyy tooooo often.
You can get free shipping off www.specialtech.co.uk if you get 25 posts (or already have) on oc3d forums
Quote from: AvengerUK on Aug 11, 2007, 03:06:17
Depending how many drives you hang off the machine, my instinct would be to upgrade to 700W or better and give yourself a bit of headroom.
mrapoc
You can run that off a 580w easily I should say unless ur gonna go SLI - then get 600w+. Stability of the voltage on the rails is probably a lot more important than the wattage rated tbh  :)
AvengerUK
Yeh, well ive just found out that my budget is considerably bigger than first thought (as this is my 18th "Treat") - so it may end up being rather different!
RE: mrapoc, ye im aware of overclockers rep, as ive suffered (by the tune of a weeks wait - and a very rude customer services guy) when trying to replace some RAM. - however, buying from them is extremely convienant for me, as its not a long drive to pick stuff up - that said, microdirect and aria PC (Aria being the company who won the er, PC world or w/e awards) arnt far either!
AvengerUK
Quote from: Rik on Aug 11, 2007, 10:27:16
decided on: http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-HP&groupid=701&catid=123&subcat=461
Similar to my current, just 100w more - should be ample i hope!
AvengerUK
Quote from: Rik on Aug 12, 2007, 17:00:14
Slightly cheaper at Scan:
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=465734
Looks up to the job. :)
Add postage and it aint :)
(although petrol is proberbly going to be more...)
Anywho, im off to enjoy some early morning birthday drinks ;)
zimmerframe
Definatly go with a higher capacity PSU. If you are going with an 880 Ultra, a minimum of 600W for stability.  Some modern PSU are modular so you dont have all those unnecessary wires cluttering up the inides of your case.  I think the 880 Ultra needs two PCI-E power connectors btw.
Are you sticking with the stock Intel HSF?  If not, the Artic freezer Pro http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR&groupid=701&catid=57&subcat=821 is still apparently a cracker.
If The World Didnt Suck, We'd all Fall Off
Quote from: AvengerUK on Aug 13, 2007, 01:35:36
Happy birthday!  :beer1:
Have a karma to celebrate.  :)
