Macrium Reflect query
Started by Broadback, Nov 22, 2018, 15:13:01
Broadback
What is the difference between the free and the bought versions? I have tried asking the company, but go tot no answer?
Broadback
I've found the answer, if anyone else is interested. It is here:
https://www.macrium.com/reflectfree
Sorry, was busy so did not get to reply. XD
I just realised, I use Macrium for full copies when making new PCs. But it seems to work fine.
I use Paragon Backup & Recovery Free for my daily backup solution. For example, I realised I'd deleted a load of archived files I needed suddenly, but found my 2015/16 archive and pulled out the My documents folder from it. That was using the free version. However I found out versions may not be compatible due to recent upgrades they did. :( So I have 2 versions installed.
So Macrium might work out better and simpler for your PC?
