Problems tonight?
Started by psp83, Sep 04, 2007, 21:36:56
Anybody else getting slow speeds, high pings and sites loading slower than normal tonight?
ReDGryphoN
Nope, all sweet and solid
ReD
MAABOF
BILLION 8800NL USER FTTP
Henry David Thoreau
drummer
#2
Today (Monday 4th) was a total pig for speed all day, but it's all back to normal now.  :)
I joined IDNet on Sept 1st 06 so this is (sort of) my 1st anniversary.
I'm struggling to moan about something, so I'll stick with BT shoving me onto interleaving when everything was disconnnected over the Xmas hols.
Long story short; moving to IDNet was probably the only sensible broadband decision I've ever made...
Well have a anniversary karma!
I didn't notice any problems at all last night, fwiw.
Likewise, have another Karma for your anniversary, I also didn't have any speed issues. ;)
I wasn't on line, so I didn't have any speed problems either. ;) Congratulations on your anniversary, Drummer. :)
Back to my normal 7megs and 16ms pings tonight :)
Have you looked at your error count, Paul? I just wonder whether you had a noise problem which was causing re-transmissions.
Wheres the error count on netgears?
Hi Paul
Enter this in the browser address bar:
http://192.168.0.1/setup.cgi?todo=debug
which should result in a screen which just says 'Debug enable'.
(That's assuming that you haven't changed the router's IP address from the default).
Then exit from the web interface and open a command-line window. Type:
telnet 192.168.0.1
You should get a BusyBox welcome message to confirm that your telnet connection is established.
Now type:
cat /proc/avalanche/avsar_modem_stats
You'll see the errors listed.
doesnt work :(
I get the welcome screen, but when i type in the line, says it cant find it or something
If you were using Firefox, try from IE. Netgears seem to be hard-coded for IE.
Thought: If you're running Routerstats, quit that first.
ok, debug is now on.
I've telnet the router and got the BusyBox message.
When i type in cat /proc/avalanche/avsar_modem_stats i get cat: /proc/avalanche/avsar_modem_stats: No such file or directory
My typo, sorry:
cat proc/avalanche/avsar_modem_stats.
still the same message :(
Odd, I've just done it, hence spotting the typo. What firmware version are you running?
I've got the stats up now, I've got a DG834PN so must be different commands.
telnet 192.168.0.1
cd usr/sbin
adslctl info --stats
Will post stats in a min.
adslctl: ADSL driver and PHY status
Status: Showtime  Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 790
4 Kbps
Link Power State: L0
Mode:                   G.DMT
Channel:                Fast
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       8.1             26.0
Attn(dB):       41.0            25.5
Pwr(dBm):       19.8            12.1
Max(Kbps):      7936            1192
Rate (Kbps):    7904            448
                        G.dmt framing
K:              248(0)          15
R:              0               0
S:              1               1
D:              1               1
                        ADSL2 framing
MSGc:           1               1
B:              248             15
M:              1               1
T:              1               1
R:              0               0
S:              1.0000          1.0000
L:              1992            128
D:              1               1
                        Counters
SF:             4061763         4061761
SFErr:          131576          0
RS:             0               0
RSCorr:         0               0
RSUnCorr:       0               0
HEC:            70895           0
OCD:            1               0
LCD:            0               0
Total Cells:    1287025403              0
Data Cells:     12722849                0
Drop Cells:     0
Bit Errors:     0               0
ES:             7701            0
SES:            2422            0
UAS:            10              0
Total time = 19 hours 11 min 5 sec
SF  = 4061763
CRC = 131576
LOS = 3
LOF = 0
ES  = 7701
Latest 1 day time = 19 hours 11 min 5 sec
SF  = 4061763
CRC = 131576
LOS = 3
LOF = 0
ES  = 7701
Latest 15 minutes time = 11 min 5 sec
SF  = 39168
CRC = 7
LOS = 0
LOF = 0
ES  = 7
Previous 15 minutes time = 15 min 0 sec
SF  = 52931
CRC = 5
LOS = 0
LOF = 0
ES  = 4
Previous 1 day time = 0 sec
SF  = 0
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 52930
CRC = 10
LOS = 0
LOF = 0
ES  = 10
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 52930
CRC = 3
LOS = 0
LOF = 0
ES  = 3
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 52990
CRC = 5
LOS = 0
LOF = 0
ES  = 5
Useful to know the command set has changed, thanks. :)
Those errors don't look too high. I'd suggest you have a word with support on Monday, see if they can see any issues with your line.
I'll pop some new stats in an email to them tomorrow night..
Just to let you know. you can also change your SNR with telnet on DG834PN routers, i dont know if it works on older versions of DG834's
Is it a Broadcom chipset? That would allow SNR tweaking. It was used in the 834GT but not the 834 and 834G.
Have no idea, All i got told is that the chipset is different to the one dg834+ modems sold by ISPs.
Theres a tutorial online for moding .PN routers. And SNR is one of them.
It probably is the Broadcom, then.
Just got told that the chipset for DG834PN is called... Conexant... Don't know if this person is correct though.
Could well be, they've been making inroads into the market of late.
