Recommendation query
Started by alan, Sep 27, 2007, 10:10:24
alan
Hi..
If you recommend somebody to IDnet and they enrol for the Home PAYG broadband option do you still get the £10 recommend fee.?
Alan
Alan
I believe you get a ten pound credit on your account yes, but Rik or Lance will correct me if I am wrong
Hi Alan
They need to supply your name and the email address that IDNet use to correspond with you (ie where the invoices are sent), at the time they sign up. The £10 credit is then applied to their account and yours.
alan
Thanks both... I'll raise a query as to why a June recommendation not been paid.
Regards
Alan
Alan
