Is IDNet responsive for gamers?
Started by CatMangler, Jul 31, 2006, 13:39:51
CatMangler
Hiya,
Looking to migrate from BT and was wondering, as I mainly play online games, whether the IDNet network would be suitable? The servers I play on are typically UK and Euro based.
I have seen some really positive feedback from other forums about IDNet's customer service etc and as you guys play games, whats the service like?
Cheers,
mrapoc
i get a ping of 15 on most counter-strike servers based in the uk and a max of 30. i can even play on servers in norway with a ping of 30-50 so yes i would recommend it
Gilba
Post a couple of addresses you play on and we could do some pings or tracerts for you.
I don't play any online games anymore but I normally get low tens to the UK.
CatMangler
Thx for the replys.
I will dig out a coupla IP's when I get home.
Probly our clan server and perhaps a euro server too.
Cheers in advance.
AvengerUK
Hi CatMangler,
I moved to IDnet specifically for gaming. The pings i get are the best ive ever had, thats out of AOL, Burstfire, evoultion & prodigynet.
Ive done a few pings below:
Multiplay (UK):
Reply from 85.236.96.22: bytes=32 time=16ms TTL=121
Reply from 85.236.96.22: bytes=32 time=20ms TTL=121
Gameservers.net (NL):
Reply from 62.212.83.150: bytes=32 time=28ms TTL=249
Reply from 62.212.83.150: bytes=32 time=35ms TTL=249
Reply from 62.212.83.150: bytes=32 time=31ms TTL=249
cosmicdance
Hi CatMangler
I use the internet mostly for gaming, BF2 here.
The pings I have had over the past week since joining Idnet have been stable and fast.
Always great low pings to UK servers and abroad too, never fluctuates at all
Can't recommend them enough here.
Andy
Like barmy animations? Visit www.sbsq-productions.co.uk
AvengerUK
I should point out that my ping results above are FALSE. i rebooted my router after that, and they became stable :)
CatMangler
Hiya @ home now.
Could one of you helpfull chaps ping a coupla servers for me, as above.
Our clan server is
Pinging 85.236.101.70 with 32 bytes of data:
Reply from 85.236.101.70: bytes=32 time=12ms TTL=117
And a euro server is:
Reply from 85.131.253.67: bytes=32 time=30ms TTL=48
Reply from 85.131.253.67: bytes=32 time=31ms TTL=48
Just as a comparison would helpful.
I'm 90% certain of switching anyway  ;D
Just as a bit of geographic info I live in East Northants, if you could include where you are pinging from would be kewl too.
Cheers,
maxping
I play Call of duty 2 and get great pings and stable connection.
Jeff
CatMangler, hello and welcome :) That`s some name m8, either you keep puttin` petrol in a diesel car or you have a feline death fetish :D
CatMangler
Ok, hmm you figure it out.
BTW, its not for filling the motor up with the wrong fuel :P
Gilba
Here you go a couple of pings.
Reply from 85.236.101.70: bytes=32 time=15ms TTL=120
Ping statistics for 85.236.101.70:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Minimum = 15ms, Maximum = 15ms, Average = 15ms
Pinging 85.131.253.67 with 32 bytes of data:
Reply from 85.131.253.67: bytes=32 time=30ms TTL=54
Reply from 85.131.253.67: bytes=32 time=31ms TTL=54
Ping statistics for 85.131.253.67:
    Minimum = 30ms, Maximum = 31ms, Average = 30ms
Im from Berkshire
CatMangler
