Does anyone know visual basic?
Started by mrapoc, Nov 03, 2007, 11:30:29
mrapoc
Its a bit complex for me:
Basically I want to add a time-based progress bar purely for appearance.
I know i need to either make a loop or, use a time based command. My lecturer didnt want to go that far but hes pleased im experimenting and wants me to have a go at home/do some research.
Im basically just trying to see how many simple yet cool things i can implement.
Heres is my code, you can probably guess what it does if you know how to add this damn progress bar!
I then want to make a picture/event happen after progress bar fills -but i think i can manage that
Quote
Public Class Form1
Private Sub ButtonPress_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButtonPress.Click
'gives a message related to user's name and shows time
LblOutput.Text = "Hello, " & TBInsertText.Text & ", Would you like to see a cool picture?"
LblOutput.Visible = True
TheTime.Text = "The time is: " & TimeOfDay
TheTime.Visible = True
End Sub
Private Sub TBInsertText_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TBInsertText.Click
'blanks text from box when clicked for user input
TBInsertText.Text = ""
End Sub
Private Sub ButtonPress_MouseClick(ByVal sender As System.Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles ButtonPress.MouseClick
'makes button visible after pressing "press me"
PictureButton.Visible = True
End Sub
Private Sub PictureButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles PictureButton.Click
'Makes picture button blue when pressed and makes progress bar visible
PictureButton.BackColor = Color.Blue
ProgressBar1.Visible = True
End Sub
End Class
Cheers
mogden
Something like this should do the trick:
You'll need a couple of declarations at the class level:
    Private Shared mytimer As New System.Windows.Forms.Timer() 'timer
    Private Shared exitFlag As Boolean = False 'exit flag
Then Two subs:
        With ProgressBar1 ' set up minimum and maximum values
            .Minimum = 0
            .Maximum = 100
            .Value = 0
            .Visible = True
        End With
        AddHandler mytimer.Tick, AddressOf timereventprocessor ' timer one second interval
        mytimer.Interval = 1000
        mytimer.Start()
        While exitFlag = False ' keep going until exitflag is true
            Application.DoEvents()
        End While
End Sub
    Private Sub timereventprocessor(ByVal myobject As Object, ByVal myeventargs As EventArgs)
        mytimer.Stop()
        Me.ProgressBar1.Value = Me.ProgressBar1.Value + 10 ' add 10 to progressbar value
        If Me.ProgressBar1.Value < 100 Then
            mytimer.Enabled = True
        Else
            exitFlag = True
        End If
    End Sub
Matt
ceci n'est pas un .sig
mrapoc
Cheers mate I sorted it
Added a timer
Made a relation between timer interval and progress bar value and it works now  :laugh:
Karma for your effort  ;)
