Interleaving problems
Started by mrtwig123, Nov 15, 2007, 11:14:52
mrtwig123
Hi
I had interleaving disabled a few days ago, I had a sync of 7000 and a profile of 6000 and everything was working well.  This morning my sync speed was down to 300kbps and my profile was at 135kbps!  I rebooted my router and I'm back up to a sync of 5000 but still have a profile of 135kbps.
Do you think turning off interleaving caused this or could it be something else?
Interleaving is used to stabilise a line, but it could be simply that you had a bad burst of noise.
The profile will take a little while to catch up with the higher sync speed - anything from 75 minutes to  5 days, depending on who you believe at BT. :(
Kheldar
yeah i'm still waiting for my profile to catch up to a decent speed after 6 months Rik.
you cannot trust them BT people who tell you it will be done in 5 days
:laugh:
mrtwig123
ok thanks, I'll play the waiting game.
It was working fine until I decided to "tweak" it!  Why do I always have to play around with things?!
Kheldar
always fatal to try tweaking !
Quote from: mrtwig123 on Nov 15, 2007, 11:29:09
It's what we do.  ;D
Kheldar
i try not to cos i am not a qualified 'tweaker' !
Then you should sign on as an apprentice forthwith. :)
Kheldar
Kheldar
Kheldar
how sucessful i am i leave to others  ;D
You've written your will?  ;D
