Please help
Started by VaderDSL, Sep 12, 2006, 20:53:13
VaderDSL
Hi, I need help, urgently.
Basically it is to do with Clarkconnect. First of I am on IDNet maxDSL package. I have a Draytek Vigor 2600 ADSL Router.
Basically I cannot for the life of me get the internet connection to work through clarkconnect. I simply don't know what to set.
Do I have to bridge my router to the CC box so the CC box acts as router?
Do I have to disable the DHCP server on the router?
Do I have to set a DMX on the router to a particular IP?
If anyone has experience with Clarkconnect, I would be eternally grateful for some help :)
maxping
Give customer support a ring in the morning .
Is this of any use - http://newbie.valar.co.uk/
VaderDSL
Cheers, Ive managed to sort another option :D Its a bit of a hash, but basically I have a spare PC plugged into my router with XP installed. Into that PC I have a wireless Apple router plugged into and a software program on XP controlling badnwidth on the specific NIC so that download and uploads are capped around 50 down 15 up.
