downtime today ?
Started by psp83, Jan 16, 2008, 21:55:53
Between 12:35 to 13:10 my router log showed the connection was down. anybody else have any downtime?
INF       2008-01-16T12:38:52Z      lmd:  dsl0: down (signal lost)
WRN    2008-01-16T12:38:53Z         vrsip:  Broadband connection lost
Opps wrong part of the forum  :-\
Adam
Adam
hehe, thanks for moving it  ;D
Quote from: psp83 on Jan 16, 2008, 21:55:53
A loss of DSL signal is not to do with the ISP. The PPPoA session was only lost following the loss of sync.
This is down to your line for some reason. Perhaps the SNRM dropped too low; that's usually the reason. If you've reconnected at a similar rate, I wouldn't be too concerned. If it starts to happen regularly (so much so that it impacts upon your bRAS profile, or worse your target SNRM) then we can look into it in a bit more depth for you. :)
the snr was at 8 and when it reconnected 20+mins later the snr was 9 and dropped back to 8.
after looking at the logs more there was several "dsl0: down (signal lost)" in the morning.
We had BT down the road today working on the underground thingys.. perhaps they was at the exchange aswell doing some work
It's certainly possible. The router shouldn't be losing sync at 8dB. See how it goes. :)
Nothing in my router logs at all, but you could well be right about it being BT!
No downtime at all here, I concur - BT strike again. :(
